What size tire for my '90 Burb?
Discussion in 'The Garage' started by cbbr, Oct 5, 2004.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    What size tire for my \'90 Burb?
    I'm soon to put tires/wheels on my 1990 3/4 ton Suburban. It is completely stock (95k original miles) with a 10 bolt front and a 14 bolt rear (8 lug 16" wheels). 350 tbi and .410 gears.
    Sugestions/experiances with tires? I am looking at either 35's or 37's but don't want to cause more problems than I cure. I also plan on lifting the truck at least 6 inches with a suspension lift.
    I will spend a lot of time on the highway driving to/from camping, so I am looking at radials.
    Suggestions?
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: What size tire for my \'90 Burb?
    My 35's fit fine with 4" of lift....
    With 37's, you will probably want more gear too, if you have an OD trans. I think the 37's and a 4.10 gear will make OD useless if you want the tranny to live. 5.13's would work well with that combo, really....
    I have 3.42's turning my 35's, and never use OD. I am switching to 4.56's and will only use OD when going quickly down an interstate.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    36" Ground Hawg 2's. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  4. cbbr
    Jul 17, 2004
    14,681
    3 speed tranny w/out overdrive.
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Welcome to the show, ya came to the right place for ideas /forums/images/graemlins/thumb.gif
    To the top.
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    If it were me I would run 35" muds. If your doing a lot of highway driving I wouldn't go to much bigger.
    I use to be one of the few who claim no front end damage while wheeling with bigger then 35's on a 10 bolt but not any longer. I messed up one of my axle shafts on my last excursion so if you want reliablitly I would say 35's.
  7. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    36" radial swampers /forums/images/graemlins/waytogo.gif
  8. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    36" radial swampers
    I second that!
  9. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    If you spend a lot of time on the road, I'd stick to a 4inch and 35's. Otherwise, you'll need to re-gear, and with 6 inches, you'll probably need some driveline mods.
  10. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I've got a 91 Burb, 4.10 gears, 350, 4L80E trans (overdrive) and stock suspension. I went with BFG Mud Radials 255 85R 16, 33.3" tall, 10" wide. They clear fine, no lift or trimming. The truck is a little doggish, but a 350 in that size truck is gonna be that way.
    Eric M.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd go with either 35s or 37s, probably 35s because they're much cheaper.
    4.10s without overdrive will pull 37s if you want, but in a heavy truck, I'd go with 35s.
  12. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Go with 35s and regear to 4.56s! If you don't you will hate those bigger tires. My sub was 3.73 and with 33's it was a dead dog! With 4.10s and 35s you would have about the same effective gearing.
    If you don't do much mudd running then BFG ATs are good tires.
    I also run Wild Country TXRs on my PSD and they are really nice tires too, plus less money than most.
    Tim
  13. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    with no overdrive and running between 36's and 39's what's a good choice in gears?
  14. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    [​IMG] /forums/images/graemlins/peace.gif
  15. 85HeartBurb
    Jan 10, 2002
    735
    Temecula, south
    SORRY THOSE ARE 42'S WITH APPROX 7" LIFT!!! /forums/images/graemlins/eek.gif
  16. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thats' my favorite sub /forums/images/graemlins/peace.gif
  17. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have 4.56's and 35's and it sucks driving down the highway. I will probably swap my 3.73's in instead. He said he has a 3 speed like what I have, no OD. 4.10's and 35's will work ok.
  18. divorced
    Jul 20, 2004
    5,115
    or is it "My 35's fit fine with 4" of lift and fender trimming"....?
    I have about 9" to 10" of lift and no trimming and still rub the front fenders when flexing. /forums/images/graemlins/confused.gif
  19. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    They fit fine with no trimming. Of course The Mall /forums/images/graemlins/rolleyes.gif is not really very challenging. /forums/images/graemlins/histerical.gif
    Kind of waiting til the axles are in and a spare tranny or two /forums/images/graemlins/whistling.gif
  20. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    i put 235/85 16's on my 90 burb same engine tranny combo as you. the tires are close to 33" tall. my rpms are 4000 at 65mph it sucks! i thought about 35's but didn't want to lift it till my other truck is done. my 67 does have 35's 410 gears and a th400 also. i haven't put a tach on it but highway rpms are much better! there is a formula for figuring rpm with tire diameter maybe someone has it handy? /forums/images/graemlins/grin.gif
