What Size Tires Can I Fit?
Discussion in '1992-Present Chevy & GMC models' started by ChevyHuny, Feb 23, 2002.
  1. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    All of you out there who own 90s style chevy trucks, what is the biggest tire size you can fit or HAVE fit under your trucks without lifting it. I have a 96 Z71 and I would like to know what the biggest I can fit without lifting it. I know there are charts and things out there but I would like to hear from someone who has experienced it or seen the trials and errors themselves. Thanks! :o)
    If you didnt build it, it isnt really yours.........
    <a target="_blank" href=http://mandydyer.tripod.com/index.htm>http://mandydyer.tripod.com/index.htm</a>
  2. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    stock rims..285/75r16 or 305/70r16
    <font color=blue>Shorts</font color=blue>
    '94 K1500
  3. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    I moved up in rim size on the Suburban as well-
    305/70/16 good years
    and 16X9 rims
    the only problem you may have is when you get off the highway- and bank- at a high rate of speed---
    you know the black plastic thing thats under your bumper? My tire guy shaved off the end of that. on an angle just so I wouldnt rub- I never did, but it was a precaution.
    if you want rims---- I have some LOL CHEAP CHEAP
    Brandy
    HELP!!!!! I need 16.5x 12 rims -------please please please!!!!!
    oh, still LOVING the new dmax as well!
  4. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    on my buddies 92 step-side I fit 33x12.50 on a 15x8 I trimmed that same thing on his no rubbing!!
    NO LOCKER, STOCK GEARS, NO PWR BRAKES, NO POWER STEERING, NO PROBLEM!
    HIT IT FULL CHICKEN!!!!
  5. finnd
    finnd Registered Member
    Dec 27, 2001
    65
    Northern Virginia
    MudNurI
    What year and model Suburban are you running those 305's on? I have a 1999 K2500 'burbon and am about to get new tires. Trying to decide between the 285/75 and the 305/70
  6. MudNurI
    Jul 15, 2001
    2,113
    VT
    it was a 94 GMC SLT 1500 4x4...
    Not sure about the 3/4 - compared to the 1/2, however I think the 3/4 sits up a bit higher than the 1/2 to begin with, you should have no problems with the 305's fitting under it.
    good luck
    Brandy
  7. finnd
    Dec 27, 2001
    65
    Northern Virginia
    MudNurI ,
    You wouldn't happen to have a picture of the shaving that was done would you? The frontend of your suburban? I already ripped off my stock bumper and tossed on the TJM T-13 that I had on my yukon. It doesn't have a hanging air dam or anything, and would seem to give a bit more room in the tire area.
    Thanks,
  8. MudNurI
    Jul 15, 2001
    2,113
    VT
    I dont have a picture, but let me try to explain it enough so you get the idea...
    its the black plastic thing that hangs down from the stock bumper...
    what they did was start at the top where the thing meets the bumper- and shave it off towards the bottom, BUT they went IN towards the CENTER of the plastic thing, 2 inches, so the piece that that they cut off, almost would look like a an L that you connect the top and the bottom wtih a straight line....does that make ANY sense?
    unfortunatly, my truck is now in Syracuse, NY, so I have no way of getting a picture. all in all I think if you dont have the piece, you probably have more room that I did, even after shaving it.
    Brandy
  9. finnd
    Dec 27, 2001
    65
    Northern Virginia
    Thanks for the info. Now my only problem is finding good tires in the 305/70 size. I loved my BFG AT's but they aren't available in 305. I do a minimal amount of off road, basically the trails to get to the hunting camps and such, so I don't want to go to the MT's. :-( Anyone know of a good AT out there that comes in the 305/70r16? Any thoughts on the new Nito terra graplers?
    http://www.nittotire.com/mainframe.asp
