What size tires should i get???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cryptobiotic, Jan 1, 2003.
  1. cryptobiotic
    cryptobiotic Registered Member
    Dec 31, 2002
    53
    Utah
    I gotz an 83' with a 4 inch lift, what are the largest tires i could fit under there? i know that 35' will fit but could i go bigger? also anyone know of any good websites for tires?? /forums/images/graemlins/k5.gif
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    well i ran 36s with my 4" but obviously you'll have to trim the fenders a little. i'd get 35s and trim em back a little.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What kind of wheeling do you do? If you're into hard stuff, keep at 33", if not get 35". Also, what's your gearing?
  4. cryptobiotic
    Dec 31, 2002
    53
    Utah
    I have 4:10 gear ratio and i don't wheel too much /forums/images/graemlins/rotfl.gif
  5. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    If you run 35's with a 4 in. lift you will need to trim the fenders a little. They will rub on a sharp turn with just the right bounce on pavement, and rub really bad off road if you get crossed up. I run 4 suspension and 3 body with 38.5" Boggers with major trimming on my 74. My 79 has 6 in susp and 36" but they rub badly, need to trim fenders.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    When I first got my truck, I put some 36x12.5 TSL/SX's on factory 7" wide wheels and ran it with no lift. It worked great and I only had to trim the front part of the fender and cut the lip off the rear of the fender. The rear cleared fine. Now I run 44's with 8".
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    With that gear ratio, 35's would work fine on the street.
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    28" sears road handlers. they work great for me.
  9. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I've been thinking about these. How are the turning radius with them? Sometimes I have to pull a Uturn when trying to get the best parking spot at the mall. /forums/images/graemlins/rolleyes.gif
  10. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I run 37's with 4" lift, just get out the sawzall and you can make much much bigger fit.
  11. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I run 36x12.5.16's with ~4" of lift. I cut the fool out of the front fenders, but that was mainly because I was mad /forums/images/graemlins/laugh.gif
    I'd run 42's. Yep, without a doubt, 42's /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
  12. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    35's look right on the lift size. but you can go as big as 44's if you love the sawzall and get better gears.
    For cruising the streets 4.10's and 35's will work.
