what size tires will fit?
Discussion in '1983-2005 S-Series models' started by four_by_ken, Jan 12, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    The wife has a 2000 2wd S-10 Blazer. It is a lease for 3 years. I figure that when the lease is up, the tires are going to need to be replaced. And I dont want to have to buy new tires and then give it up. So, I am going ot get some new tires now and then swap back to the original tires when I turn it in. So, my question comes to, what size can I fit on there?
    It has 235/75s right now. I think that measures like 28.5 inches. Can I get 30s to fit?
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  2. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    no answer?
    '86 K5 in parts
    1-ton 454 44 TSLs
  3. Jamus
    Jamus Registered Member
    Jan 10, 2002
    29
    Morgantown, WV
    I'd suggest staying on the safe side and keeping a 235/75 size. I used to own a 93 2wd S-10, older body style but should be close, with 30's that rubbed fairly bad. I ended up buying a pair of Dick Cepek 2" coils and some shackles to keep the rubbing to a minimum. Also, I think the newer body style trucks have less clearance in the fenders, don't know for sure. I figure you don't want to mess with the suspension on a lease rig. Hope this helps.
    94 Blazer, 4.3 cpi, 3" body lift, SFA with dana 30/Ford 9", 33's
  4. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    I've got the stock tires on my '95 Blazer, and I don't see how you could really fit anything much larger without a lift. On the back, maybe, but not on the front.
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I fit 26.5's on mine...it rubbed some at first.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  6. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Why thanks... that was oh so helpful.
    No does anyone else have some useful help.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  7. scotty1
    scotty1 1/2 ton status
    Jan 7, 2002
    166
    WV, Harpers Ferry
    You could go with the same size tire but with a more aggressive tread.
    Git there fastest with the mostest!
    Nathan Bedford Forest
  8. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Yup, this is about what I have decided on.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  9. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Hey 4 x ken, how was that not useful? try and be a bit more tactfull next time.
  10. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Because I am asking about larger tires, and stock they come with 28.5 to 29 inch tires. So why the hell would I want to go to 26.5 inch tires. That is why it was not useful.
    Ken H.
  11. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    /forums/images/icons/tongue.gif
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I wasn't really being serious...my s10 came with 205/70R14's or something like that. They were about 26" tall (and yes they looked lame). I put on some 245/60R15's (I wanted to keep about the same dia. so the weak 2.8 wouldn't have to work any harder than it has to all ready) on comaro wheels and the front rubbed some...I had to bend the inner fender to get them to fit.
