what size tires would be best
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5texan, Jan 6, 2002.
  1. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    i am saving up for tires and wondering should i go taller. i have a 4" lift and 33'' coopers now and stock drivetrain (343 gears i think). would it be best to stay with 33s and get more aggresive or would it hurt to move up to 35s to fil out the fenderwells better. i dont want the bigger tires to effect performance or mpg.
    thanks
    jared
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I'd figure out what gears you have for sure... cuz if you have 3.43's you don't wanna go bigger... in fact you might be even a bit too big tire wise for those gears with 33's.....
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I'm in shape.... round is a shape......
  3. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Any tire larger than what you now have will effect performance and fuel mileage. 3.42's aren't very low and for you to run a 35" tire, should go to something in the 4's. Possibly 4.10 or 4.56's. Lot depends on transmission choice too. T350, T400 or 465's will like 4.10's but the overdrive trans will like 4.56's with 35's. Also need to look at what you use truck for. 35's with 3.42's will stress 1st gear in city traffic because of all the stop and go driving but be great for top end cruising on the hiway. Will seem like you're in overdrive.
    87 K5, 427BBC,D60 & 14BFF, NV4500, NP208, TSM disc's,
  4. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    One of the most common mistakes people make is going to larger tires without changing gearing. It might make your truck look cool, but if you plan to wheel you will need the appropriate gearing.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74 K5 Blazer Topless W/ 35 BFG Muds
  5. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    my friend had 3.08s and 35"s for years. and never really realized how bad that was til he found this site. we just put 4.56s in his jimmy like a week ago. now that truck is awesome! i have 3.73s and 36"s but i'm doing a gear swap this spring.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    3.42 is hella low for 35s...I run 4.56s with my 35"s and it works well. I'd stick with 33s if I was you, unless you plan on building up to bigger/better things and are going to install new gears anyway.
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
