What Size Tires?
Discussion in 'The Garage' started by crazyhole812, Dec 31, 2005.
  1. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    I have an 87 3/4 ton. wheelbase is stock for now. it is bobbed and i have done the crossover steering and 52" swap with 2" lift springs and zero rates. the front and rear fenders are already cut and i can cut the inner wells in rear if i need to. so should i go for the 39.5 or 42 iroks?
  2. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I dont have a set up like yours but if im reading you right thats 7'' of lift and very flexy? So the 42s prob. will fit but rub on up travel. just my .02
  3. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    i would say if its 3/4 ton then 42's are probally out of the question. IMO
  4. fordtruggy
    fordtruggy Registered Member
    Dec 30, 2005
    55
    Red neck ville Rapid city SD
    What axels 14BFF/D44?????? if so than anything bigger on that d44 than 35s is asking for falure of the front axel.
  5. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    what motor do you have? and whats in it? if you don't have the balls to spin the tires when you get in a bind then your screwed. I've heard of way to many people who thought they wanted as big a tire as could fit and then found out they could'nt spin them. so keep that in mind.
  6. crazyhole812
    Jul 6, 2005
    228
    missouri
    sorry guys. i do have a D60 in front and 14FF in rear. my 383 should be beefy enough to spin them too
  7. crazyhole812
    Jul 6, 2005
    228
    missouri
    my main concern is how much harder on my steering and driveline will the 42's be compared to the 39.5 and is the size difference worth the weight
  8. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I would go 39.5's and since its a 3/4ton.....NEVER lock the front!!
  9. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    said he has a 60 in the front.
    some guys use hydralic steering in the front. maybe check that out.
  10. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Get the 42s and get out the sawsall and go play.
