What size tires?
Discussion in '1936-Present Suburban' started by sanddragon2004, Mar 25, 2003.
  1. sanddragon2004
    sanddragon2004 Registered Member
    Feb 19, 2003
    80
    San Jose
    about to install dana 44 front and corp 14ff rear, with 4:10s. 6" suspension lift, i may tow my small flat bed quad trailer once in a while. but mostly will just wheel at holister, and clear creek, and a few local mud holes. what size tires are good for mud for a burban? i know its a heavy ass truck, what do you guys run? what works and doesnt work? im trying to determine best combination for me.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I currently have a 4" lift and 32's( /forums/images/graemlins/rotfl.gif) but will be going to 35's once the 3/4 ton axles go in. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  3. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I'm runnint 4:10 with a D44 & 14FF. I have 4" susp, 2" body & 36x12.50x16.5 hummer tires. I trimmed my fenders a bit, but they work great. I tow a 17 foot camper into the mtns around 11000 feet. It does pretty good, considering I have me, my wife, three kids, two full grown labs, & a bunch of beer /forums/images/graemlins/grin.gif!! Anyway, it all depends on what yoiu really want!!
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i'm at 7" of lift and running 36x12.50 TSLs and i've never been stuck in the mud with my TSLs but i know my limits. i'm not gonna try something that i know is deeper than my tires.
  5. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    Since you are running 4.10's, I would go no larger than 35's. 33's are best for 4.10's but you will probably get better gas milage with the 35's.
  6. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    I'm running a 6" procomp spring in front and 6" superlift in rear and 37-12.50-15 SSR with no fender trimming, and 4:56 gears. I haul a 18' quad trailer and 4 quads with no problem. /forums/images/graemlins/usaflag.gif
  7. bigreid
    bigreid Registered Member
    Mar 8, 2002
    21
    Anchorage, Alaska
    What are your experiences with 33" and 3.73 gears. Just right or would 4.10 be better. If 4.10 are better what is the average cost to make the change? /forums/images/graemlins/burb.gif
  8. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    [/ QUOTE ] So what you're saying is that when our burb gets the 3/4 ton axles with 4.10's and still running 31''s (and we plan to keep it that way /forums/images/graemlins/grin.gif) we will get bad mileage? /forums/images/graemlins/rotfl.gif Don't tell the girlfriend, it is her truck /forums/images/graemlins/ignore.gif sure will be quick at the stop lights though /forums/images/graemlins/thumb.gif
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    YPU DIDN'T STATE WHETHER OR NOT YOU ARE RUNNING AN OVERDRIVE TRANSMISSION OR NOT. WHAT DO YOU LIKE FROM YOUR TRUCK, PERFORMANCE OR JUST GET YOU THERE? YOU KNOW YOUR TRUCK BETTER THAN ANYONE ELSE, AND WHAT YOU EXPECT IT TO DO. WHERE DOES YOUR ENGINE MAKE ITS POWER? WHAT RPM DO YOU SPEND MOST OF YOUR TIME AT? DO YOU DRIVE MOSTLY HIGHWAY OR CRUISE AROUND TOWN? MORE INFORMATION, BETTER ANSWER. TRY GOING TO INTERCOS WEB SIGHT AND USING ONE OF THEIR CALCULATERS TO PLUG IN TIRE SIZE GEAR RATIO SPEED YOU WANT ETC. YOU MAY EVEN COME UP WITH THE ANSWER TO YOUR OWN QUESTION.
  10. sanddragon2004
    Feb 19, 2003
    80
    San Jose
    Im running a 700r4
  11. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    On my 91 with 2 inches of lift the 33 inch BFG fit good.
    But the 4.56 gears are a little low for the tires.
    Next set of tires more lift and 35s.
    With 6 inches of lift 35s or 37s will fit easy, but you will need 4.56 gears for sure.
    With 4.10 gears and only a 350 don't go with tires bigger than 33s or you will cook your auto tranny.
    Tim
  12. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    4.10s about 33's. just use the OD on the freeways. With that 6 inch lift, i would look for even deeper gears now, and taller tires in the future that can fill in the space better. you'll appreciate the extra ground clearance.....
  13. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    I RARELY USE MY OD NOW.....
  14. sanddragon2004
    Feb 19, 2003
    80
    San Jose
    Right now i have 33" tires and 3:73 gears, i have expereicned no problems, towing or anything. i can still cruise at 75-80mph on the freeway. I tow a flat bed quad trailer and 3 banshees no problem. (dont even realize they are back their)
  15. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    if you drive like that and are happy with the performance, then 35's and 4.10's will be close enough to the same thing that you probably wont notice much difference. most suspension man. recommend 35" tires with a 6" lift anyway, and no fender trimming. most of my trips are short hop, so I like more snap when i push the go pedal.
  16. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    by the way, my sub has 303,000 miles on it, not sure how many are on the motor. I will be checking this out soon and opening her up more to my liking.
    my '77 K20 just fell apart around me, lots of good parts 4 swapping into this one though.
  17. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    DAMN someone who has more miles than me!!!!! NNNOOOOOOOOOO!!!!!!!!!! J/k man, I got 277,000 on my 89, I tell people its just been broken in /forums/images/graemlins/thumb.gif
  18. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    a survey crew owned it b4 I did, they are responsible for most of those miles. but thats why I got the killer deal of $700 for the whole thing. everything worked, and still really solid considering I'm in the rust belt.
