what size trailer winch do you use???????
Discussion in 'Tow & Trailer' started by JEBSR, Jul 7, 2006.
  1. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I want to put a winch on my new trailer but I can't afford a nice 8000 or so winch after buying a new trailer, box, etc. Thinking about putting a 2,000 lb mm trailer/atv winch on for now. Anyone have any experience with these?
  2. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    well i have a 1ton truck and to pull it up on my trailer it uses all its power. i have a 6k ramsey i got used but like new.
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    it's too light duty for a full size vehicle imo. You will need to use a snatch block to double the power at the very least. Have you looked at the cheapy harbor freight ones? I have used a 8K one for general utility stuff and it worked great. not sure if i'd trust it in the woods, but for a trailer it would be good.
  4. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Thats what I'm thinking too. Just trying make something work that I shouldn't I guess. Oh well sooner or later I'll be able to pick up another good winch.
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I got a 8k ramsey and it had to work a little to pull this bos truck on the trailer with a straight line. if you get a china winch you really need a snatch block IMO
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I use a Harbour Freight 8k with a snatch block, pulls it right on up.
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I just pulled a 73 K5 onto the deckover (with 8' ramps) on Sat. First time I actually used the 2000 lb winch. The winch stalled with a straight pull, had to use a snatch block. HTH
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    It seems like this would be the perfect place for one of the cheep Chinese winches. Unless you can find a good deal on a Ramsey RE worm drive winch. I've got a Warn XD9000 on mine, mostly because that is what was there when I bought it. I've used it to pull a couple ton boulder off my trailer and to pull an axle-less pickup on and off it. I wouldn't go any less than 6k lbs. Either way make sure you use a good battery.
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    An 8K winch isn't necessarily a bad idea to use on a trailer, but a majority of the time you really don't need that much power. On the other hand a 2K winch would likely be a little small if you wanted to haul fullsize trucks onto the trailer, however if you unspooled the cable down to the last wrap and had a good battery it probably could pull most free-wheeling trucks onto a normal trailer..........remember that with each layer of cable still on the drum you are losing a LOT of pulling power.
    Just keep in mind that even if the trucks weighs 8,000 lbs., you don't need anywhere near that amount to roll it around. However the power of a larger winch could be nice for dragging stuff like rocks or vehicles sitting on the frame onto a trailer.
  10. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I plan on putting an old 8274 I have laying around on a multimount to use on my trailer. What size wire should I run from the battery to the rear of the tow rig to power it? (~20 feet) 1/0?
  11. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    I have one of those HF 9500 *just like the milemaker*
  12. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    put a fullsize battery on the trailer with heavy gauge wire to the winch. with a decent size trickle charge wire for it from the truck. thats what I have. you are only pulling hard for a short distance. just up the ramps, the length of the deck is easy. I just let the towrig idle while I am pulling.
    I pulled a truck up without a front axle and didn't have any problems with draining the battery. used a crappy no name 8000 lb winch.
  13. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    My solution...........
  14. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    I've got a Champion 3000lb winch from Tractor Supply on my trailer and it'll pull a 1 ton truck on good tires with single line or a car on flats with a snatch block. It's good enough for my needs.
  15. ThaMule
    ThaMule Mursenary
    Jul 29, 2005
    2,002
    Murfreesboro, TN
    Dontoe.......It looks like that receiver hitch is just welded at the top and then on the bottom to the trailer. How much weight have you pulled with it done like that. I am looking to put something on my trailer and that looks like the simplest thing I have seen.
