What size U Bolts do I need?
Discussion in 'The Garage' started by NEK5, Feb 16, 2007.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Axle in question is 1/2 rear, 10 bolt. I need new ones, as I`ll be putting the flip in next week, and taking out my rear blocks....I`m also adding a 1" zero rate, so take that into effect...
    I know 3" axle tube dia. and I believe 5/8`s thread? what about length?
    TIA
  2. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ttt
  3. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    Will you be using an overload leaf? And how many leafs do you have?
    I have 10B rear also with 5 leaf 56s , no overloads, and will be putting in 1" zerorates with 8" ubolts. One side has 10" ubolts which I realized later that they were way too long, so I'll be cutting it down to 8".
    I will be swapping to 14B and I'm hoping 8" will be sufficient.
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I`ll be using a 1" zero rate, and the springs are stock, for a 90 Blazer...
  5. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,238
    284
    San Jose, California
    Depending on who you get your shackle flip from they should be able to tell you what size you need. If you have no blocks and a stock perch, then it should be easy for them.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Well, I already got the flip, from DIY4X.
    Does anyone know the stock size of the U Bolt on a 10b rear? and would I just add an inch to compensate for the zero rate?
  7. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    8" should be enough, you'll probably come within an half inch of threads exposed. Ask around a bit more if you're still unsure.
  8. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    What are the actual risks of re-using u-bolts? I've been doing reading on it. Every author mentions torque yield or something like it and don't do it.
    Is there a risk of breaking, not holding, loosening up? I've got my shackle flip, zero rates as well and a set of stock u-bolts off another blazer. Just trying to find time to put on.
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Yeah, that and there could be a hairline crack somewhere, and you wouldn`t know until it broke....
