What size u-bolts?
Discussion in 'The Garage' started by BigCountryx, Jun 24, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    What size u-bolts and studs do I need for my front D60 and also U-bolt size for my 14ff? Trying to get my springs and u-bolts all ordered at one time.
    Scott
  2. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    You could check ORD's website. That's where I ordered mine from :D
  3. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    5/8" 3-3/8" by however long you need
    for grade 8 14BFFs.
  4. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    For the Dana 60 get SuperLift Kit part # 3418, unless you intend on using a set of Zero Rates up front, then you may (or may not) need longer U-Bolts.
    The two Left side U-bolts on a Dana 60 are 5/8 X 3-1/4 X Length.
    The one Right side U-Bolt on a Dana 60 is 5/8 X 4 X Length.
    The Right side Bolts (or studs) are course thread 5/8 X 4 (can be either 5" and sometimes 6" long if using a Zero Rate up front).
    Corporation 14-Bolt FF are Square Bend U-Bolts 5/8 X 3-3/8 X Length.
