what size welding cable to use for battery install
Discussion in 'The Garage' started by beater74, Dec 7, 2003.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i am collecting parts for my dual battery install and relocation. i will be putting 2 red top optimas behind the front seats. what size welding cable should i get 1, 2, or 1/0 gauge /forums/images/graemlins/confused.gif
    i want to use welding cable cause of it's flexablity and i can use a smaller gauge cable
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The largest you can afford, but really depends on the length of cable and the draw it requires but usually 00 cable is best
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I used two.
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    dont use welding cable, use battery cable...i forget where but ive read that welding cable is not acceptable to carry battery current (amperage)...
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is bullshit.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    uhh I've seen plenty of applications using welding wire. Seeing as welders put 200+ amps through those wires I'd have to say thats bull. I'm gonna do my whole setup with zero guage. Since I'm moving the battery to the back of the K5 and want to do some real good grounds.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Welding cable is fine. The finer conductor will probably pass MORE current than regular thick ass battery cables. I've still got those things for the regular cables in number two, but I run welding cable for my 2nd battery and that's what I'm going to run for my winch, too. If I could have found it thicker, I would have ran that, but they only had 4 or 2 so I got 2.
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    That is bullshit.
    I agree with Tim on this one. (can ya believe it? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif)
    Welding cable will take plenty of current in the correct AWG. However, the one reason not to use it is the insulation. It is not rated for automotive use.
    But.... with that said, I use welding cable for my stuff and have never had a problem.
    John
  9. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    i would think it's a corrosion issue, not a voltage issue...
    alot of the boats i work on i see systems done in welding cable, some hold up, some turn green.. great for routing tho, bends so easy. this is huge diesel stuff too, 1/0, 0/0 etc...
    i would think the best thing you could use is marine battery cable. thats what i used for the trunk-mounted system in my Chevelle.. tinned copper holds up very well..
    my.02 /forums/images/graemlins/smile.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I am about to do a search on it and quote every time I've heard that the last two or three weeks. /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif I wish I had a dime......
  11. beater74
    May 29, 2001
    1,749
    atlanta
    thanks /forums/images/graemlins/thumb.gif
    i guess i'll just order so 1/0 gauge. it can hurt.
  12. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Just saw your avatar /forums/images/graemlins/rotfl.gif /forums/images/graemlins/crazy.gif
