What size winch????
Discussion in 'The Garage' started by TB2Blazer, Nov 7, 2004.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    I'm thinking about buying a winch for my K5 and was wondering if a 9500lb would be big enough or do I need to go bigger?
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I have both the warn 8274 and m12000 winches. You can't go wrong with those. The 8274 is mounted on the front & the 12000 will be going on the rear soon.The 9500 should work but just in case buy a snatch block to double the capacity. What kind of wheeling are planning to do? If its deep mud then bigger is better /forums/images/graemlins/thumb.gif
  3. TB2Blazer
    Apr 6, 2002
    166
    Cleveland, GA.
    Not much mud more geared towards rocks but will occacionally see mud.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    9500 is fine.
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I get by with a M8000, you should be fine with a 9500. Basically the biggest Winch you can afford is a good rule of thumb, and can't go wrong with a Warn /forums/images/graemlins/thumb.gif
  6. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Depends on the kind of wheeling. If the mud you run is deep and sticky... I wouldnt go under a 12k.
