what size yoke on this axle
Discussion in 'The Garage' started by **DONOTDELETE**, Jan 1, 2003.
    its a 14b ff from a 1990 k30 crewcab, i thought it would be a 1350, but i already have a 1350 on my truck and it doesnt fit, the caps on my u joint seem too big.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have never heard of a 14 bolt with anything other than a 1350 (except, of course, when someone puts on a 1410 aftermarket.)
    I really don't think there is a yoke smaller than 1350 for it.
    Post a pic of it and the 1350 ujoint.
    -- Mike
    EDIT: I can't help but wonder if maybe it's the 9.5" 14 bolt? Are you sure it's a FF?
  2. here are some pics
    edit: it is the ff, straight out out a crecab k30...
  3. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    btt, btw, i changed my username...
  4. tjayandlisa
    tjayandlisa Registered Member
    Feb 14, 2002
    48
    Sacto CA
    a 1330 is the same width as 1350 but with smaller caps...
  5. 96chevysfa
    Jan 1, 2003
    230
    so cal
    could the 14bff come with the 1330? because the caps seem too big
  6. 96chevysfa
    Jan 1, 2003
    230
    so cal
    oh, a nd the clamps in the picture in the yoke are from the previous axle whihc did have a 1350 yoke, and these line up perfectly...
  7. tjayandlisa
    Feb 14, 2002
    48
    Sacto CA
    both the 1350 and the 1330 are 3 1/4 inches across caps... the 1330 uses 1 and 1/16 inch caps, the 1350 uses 1 and 3/16 caps...hope this helps...
  8. 96chevysfa
    Jan 1, 2003
    230
    so cal
    well, im positive the u joint is a 1350, but how do i tell what size the pinion is?
  9. 96chevysfa
    Jan 1, 2003
    230
    so cal
    <~~~~~~~~~~~~~~~STUPID!
    turns out there was a thick layer of rust and paint on the yoke so i just wirebrushed it off and the u joint went right in /forums/images/graemlins/smile.gif.
