what size?
Discussion in 'The Garage' started by hunterguy86, Jun 12, 2006.
What size wheels
  1. 15x8
    15 vote(s)
    60.0%
  2. 15x10
    4 vote(s)
    16.0%
  3. other
    2 vote(s)
    8.0%
  4. nekked
    4 vote(s)
    16.0%
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I need to get new wheels due to swapping the 14 bolt in. I run 35x12.50x15 procomp MT tires
    What yall think, 15x10 or 15x8?
  2. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    Get the 15x8's so you do not have as much of a rubbing problem up front.
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    I vote other because if you ever get a D60 upfront then you either need to shave the calipers or get a 16" or 16.5" rim. If not then I say go as wide as you can go. :D
    I heart big rear ends :p:
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Grinding the calipers isn't so bad. I voted 15x8's because they will hold the tire on the bead better and slightly increase the tire's height (and slightly decrease the contact patch). Unless you are in mud, height > width IMHO.
  5. copedrake
    copedrake Registered Member
    Jul 18, 2005
    27
    san jose ca
    same as they said. but a 12.50 tire is all you can fit on a 15x8 rim i believe
  6. 1977k5
    May 26, 2003
    9,996
    134
    You can fit wider, but tire/wheel manufacturers recommend no wider than 12.50" on an 8" wheel. There are people that slam 42's (15" wide) on 8" wheels.
  7. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    That is just asking for trouble, no sir not me!
  8. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Thanks yall. I went with a 15x8 wheel with 3.5 inch backspacing. Ordered the wheels, should be here this week.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I will:D . I voted 15X8 as that is what I have with 12.5s and I went down to 8 PSI and never had a problem. Poor mans beadlock:D .
    Ira
  10. greenbeater
    greenbeater Registered Member
    May 24, 2006
    19
    michigan
    i also say 8. but i have personaly wheeled with a guy with 33x12.5, on 15x6 wheels. at very low pressures and never blew a bead. but i still say 8's i think 10's leave you too exposed
