What speedometer gear do i need?
Discussion in 'The Garage' started by FarmRig, Jun 14, 2006.
  1. FarmRig
    FarmRig Guest
    Yes i put 33''s on my truck recently and did the calculater on line and its going to be about 5mph off. What gear do i need? Thank you.
  2. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    What transmission and rear end gears do you have?
  3. FarmRig
    FarmRig Guest
    4spd manual and 3:42 in the rear. Its a K10. Thank you.
  4. FarmRig
    FarmRig Guest
  5. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
  6. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    What about for sm465?
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The tranny doesn't have a tailhousing or speedo gear in a 4x4 . The speedo gear is in the transfercase regardless of auto or manual .
  8. uberbeans
    May 14, 2004
    564
    So how do I calibrate it?
  9. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    OK, I will describe how to do it. This is not the only way, but it is the way I would probably do it.
    Note: this is not really a "calibration" like you would find on much newer computer controlled cars. Those you can just plug into a computer and reset your tire/gear size and it will read correctly. You have to physically change the small plastic gears to get the correct reading with our rigs.
    First, you need to know your exact tire diameter. Get the measuring tape.
    Find your current gear ratio. Actually count the teeth or use the driveshavt vs. wheel spin method.
    Know what transfer case you have.
    Now, you have to count the teeth of your current drive and driven speedometer gears. Find where the speedometer cable goes into. It looks like this:
    Now remove the hold down bolt and gently rock the sleeve loose from its hole. When it comes out, it will contain the driven gear, which looks like: [​IMG]
    count the teeth.
    If you look into the hole, you can see the drive gear:
    [​IMG] [​IMG]
    count the teeth.
    You can use this chart, but I would always want to count the teeth myself:
    Now, using the calculator (speedometer rev/mile being 1000) and resource page I posted above, find out which combination will work for you to give you the correct reading on the speedometer face. You might need to swap both drive and driven gears.
    Images and some good info found at http://www.transmissioncenter.net/speedometer_calibration_______va.htm in addition to what I posted above.
  10. FarmRig
    FarmRig Guest
    Thank you randy88k5
  11. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Pay attention to the tooth count on the driven gear. There are two different sleeves for the driven gears; one is for gears with less than 40 teeth and the other one is for gears with more than 39 teeth. I just installed a 40 tooth driven gear in mine and had to purchase the new sleeve.
