what starter for a 6.2 w/ sm465??
Discussion in '1982-Present GM Diesel' started by k5boy1983, Sep 4, 2006.
  1. k5boy1983
    k5boy1983 Registered Member
    Aug 23, 2004
    39
    Fontana, CA
    alright yall, i got 86 k5 w/ 83 6.2 with a gas motor flywheel, mated to a cast iron (non hydraulic) bellhousing w/ a sm465 to that (also from a gas motor). (and a doubler but that dont matter).
    my problem is that the stock starter (for the gas motor) that bolts to the bellhousing (not the block) just doesn’t have enough power to turn over the motor. (which i figured since the compression is different in the diesel). and the diesel starter that i have (the one that went w/ the motor originally) a. wont fit w/ the bellhousing that i have, and b. has a different amount of teeth than the other one. which leads me to believe that it only works w/ the diesel flywheel.
    so... is there an application for the starter that i can use, (that will bolt to the bellhousing)? or do i just need to get a diesel flywheel? (hopefully not). any help would be appreciated.
    thanks.
  2. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    The 6.2 is externally balanced and uses it's own specific flywheel, so IMO I'd pony up for the correct flywheel first. Second, the 6.2 also uses it's very own starter which bolts to the block rather than the bellhousing. The better of the 2 factory starters is the 28 MT gear reduction starter.
    Rene
  3. k5boy1983
    Aug 23, 2004
    39
    Fontana, CA
    thanks for the response,
    i wasnt aware that it was externally balanced (guess ill have to look better at the harmonic balancer).
    i figured that the diesel flywheel would be better, but w/ the gasser bellhousing, the diesel starter (of which i have) will not fit (interference w/ the bellhousing). can i plasma the bellhousing till it fits? i figure that where i would need to cut is not load bearing or integral to the integrity of the housing.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You have the cast bellhousing for the small block/465, if you get the aluminum bell housing you won't have interference.
    You could cut of the interfering piece but the aluminum bell is plentifull and cheap.
  5. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    X2 on the aluminum bell...cheap and plentiful, especially the non hydro clutch ones.
    Rene
