what starter will fit?
Discussion in 'The Garage' started by bigoltrux77, Dec 13, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    I got a starter about a month ago from auto zone. I installed it without any shims. wednesday it started grinding alot and yesterday it just started free spinning. The flywheel is ok but the starter gears are all worn. Im going to replace it today but iwant to uprgade to a better starter. What is the best OEM (from any other truck)that will bolt right up to my 350 small block? I hear i should use one from an old corvette BB but will it have the same bolt pattern, or one from a new chevy with gear reduction. I want one that has a higher torque rating and a quieter start. Also how should i install the starter so that i dont break it again?
  2. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    The biggest issue is probably the brand (Auto Zone) more so than the actual starter application. Find an AC Delco brand remanufactured starter and try that. As far as what will fit, most Chevy V8 (sbc/bbc) starters are interchangeable.
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    From what I have learned there only 2 different Chevrolet starters(I think this is for small and big block) theres one for the small fly wheel and one for the big Im guessing you have the big. If you really want to spend some money on a starter I would recommend a hi-tq mini starter which should match any Chevrolet pattern. I mini starter sposibaly last longer when you have headers because its farther away from the headers and you can also (even with a regular starter) put header wrap on the solenoid (the part where the wires go in) You said you bought a auto zone starter which I don’t like because the sold me one that was already bad, but Im thinking it should have a life time or 3year warranty so you could go back and try to get a replacement. As for why the teeth are gone is its gotta is it has to be catching the flywheel when you put it in make sure when you rev it and stomp the gas in drive and rev and when you go flex even a little its not hitting if it does play with shims.
    <font color="red"> If anyone sees any part of this information to be wrong please tell me and him </font color>
    Oh yea and If you but a hi tq ask a few questions to varrify what I told you
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    you need to place 2 shims on the outer bolt... away from flywheel... only on that bolt.. you need to shim half the starter... it's what i have to do.. all the time... /forums/images/graemlins/thumb.gif
