what stock ratios are best
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86blazerk5, Sep 7, 2000.
  1. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    I am running 3s and was wondering what stock gear ratio would be best for this application, 2.73, 3.08, or 3.42? Thanks
    ike
    Spreading The K5 Gosple!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I take it you are running 33's? I would shoot for the 3.42's............ if not the 3.08's wouldn't be bad, but stay awiting from the 2.73's unless you are trying to get you K5 to go 180mph!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    With a 700R4 OD tranny and 33 inch tires, the lower the better. 4.10s would be best. With 3.42s, you will only use OD at 70mph plus. Anything higher, and you will never use OD.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i have have 3.42 with a 700R4 OD tranny and 33 inch tires, If you want a 3.42 I might be getting rid of mine. because i have a boat to tow. If your going to be driving on the highway you might be ok, with a 3.42, if it is not that hill However, if it is hill then and you plan on driving at 65 you will never get to OD.
  5. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i have have 3.42 with a 700R4 OD tranny and 33 inch tires, If you want a 3.42 I might be getting rid of mine. because i have a boat to tow. If your going to be driving on the highway you might be ok, with a 3.42, if it is not that hill However, if it is hill then and you plan on driving at 65 you will never get to OD. DONT GET A 3.08 or LOWER
  6. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I have 33s with a 700 and 3.42s. I kind of like it, all the advice given about overdrive and speeds are dead on accurate. I believe 3.73s to 4.10 would be the best range for that combo.....js
  7. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    I have 3:73's , a SM465 and I roll on 33's and I think my truck is a bit slugish! I would like to go to 4:11's but I have a lot of other things to fix on my 72 first.
    72Blazerod
  8. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Like 72Blazerod, I have 33s, SM465 and 3.73:1. It rolls down the highway well, but would be alot more fun and easier to drive around town with 4.11:1 rear ratios.
  9. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I got 3.42's with 33's and a 700r trans. i would probably drive in In D but it clunks when I slow down around 15 and it burns fluid in D so I drive it in OD. Its not that bad in OD.
    JD
    88 Gmc Jimmy
  10. 86blazerk5
    Aug 9, 2000
    387
    i currently have 3.42s a 700r4 and 33s. i undesratnd what it is that you guys are saying about that. The only reason i asked is becuase i am in need of a new rear axle. i have a donar blazer, but its ratio I do not yet know, if it is 3.42, i will just swap the rear, if it is 3.73 i will swap the front and rear, but if it is anythingthing lower like 3.08 it is unusable for me then becuase I have 33s. that why i was asking. thanks alot guys.
    ike
