What stroke for a hydro assist ram?
Discussion in 'The Garage' started by mikey_d05, Feb 2, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I know a lot of you are running hydro assist and I'd like to know what stroke the rams you're running are. I've seen a lot of people running 8" stroke rams but if I measure the travel on my steering stabilizer it actually moves about 9"-9.5" when turned from stop to stop. I'm wondering if a 10" stroke ram would be more appropriate or if 8" works better so it doesn't try and break the steering stops. Thanks for any info.
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Whatever length you get,You want everything to stop at the same time. Meaning, your ram should not extend futher or less then what your steering stops allow. If you adjust both to stop at the exact same time, your front end will survive longer.
    I ran an 8" ram on my Dana 60 witht the tie rod in the stock location. When I went to hi-steer I had to shorten my ram to nly 5" of travel.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine is 2 x 8.
  4. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Full hydro with 2x8 here on a D60.
