What swaps...10b to d44?
Discussion in 'The Garage' started by BlazerWheels, Jul 25, 2004.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    I am going to be swapping my stock 10 bolt out for a d44...What swaps? So the brake calipers?? Rotors?? Anything??
    What about from a 10 bolt rear to a 12 bolt..saeme questions... /forums/images/graemlins/confused.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    10 bolt to D44 knuckles out will swap. I don't think anything will swap between 10 and 12 bolt rear.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    On the 10 bolt rear to 12 bolt rear the things I know for a fact will swap is the backing plates , brakes , u-bolts , drums , and the hardlines for the brakes . Did this when swapping out the 10 bolt Dead-loc axle for a 12 bolt . None of the internals will interchange since the pinion/cross shaft diameter is different . I never checked the bearings and seals to see if they were the same , I think they are same inner size for the axles at least for 30 splined axles , because 30 spline 10 bolt shafts worked temporarily with a little weld on each end to make them wider , until I scored `12 bolt shafts ( got a 5 lug 12 bolt to work with ) /forums/images/graemlins/k5.gif
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    10 bolt fronts and d44 fronts are pretty much identical with respect to strength... why swap a 44 in for a 10?
    j
  5. BlazerWheels
    Feb 13, 2003
    587
    California
    j
    Don't need to go 3/4, and cheaper than having re-geared.
