What T-case and Tranny?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by KrebsATM02, Apr 2, 2002.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I came across a truck with a 75 frame and a 79 body, so the decals didn't help determine what it was. Had a dana 44 with the huge outer hubs and a 14 bolt. It was also standard. So i'm assuming a sm465, but what for the T-case?? To muddy to lay on my back and get under there. Thanks - Doug
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Should be a 10 spline NP 205 with the yoke front output.
    Rene
  3. KrebsATM02
    Mar 21, 2000
    553
    good to use for the doubler? Or just keeping looking for more compatible stuff?
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Well...it's not a weak combo, but it's not what I'd use if I was shopping with a doubler in mind. The early 205 had the yoke front output which isn't quite as strong as the later style with the flange front output. Also this is a 10 spline combo and the drivesleeve and splines are somewhat prone to wear.
    The ideal would be a SM465/NP 205 from a mid 80's K30. It's all 32 spline, but good luck finding that set-up.
    If you want to do a 4 speed doubler look for 77 and newer 205. The input can be changed to 32 spline with some basic machining and a new input gear from ORD. This is not a tough swap at all. Find a SM 465 from an 81 or newer truck...they were all 32 spline output. Then talk to Stephen about what doubler parts you'll need.
    Confused yet?/forums/images/icons/smile.gif
    Rene
