what tcase is this?
Discussion in 'The Garage' started by sweetk30, Mar 3, 2005.
  1. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    just looking for tcase info. thay say its a 205? but it dont look like one to me.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Comparing those photos to other 205 photos. THey look similar. That is definately a detached(the term is escaping me at the moment) case though...
    The bottom left hand picture shows two mounting bolts on the top. All the GM case I am looking at have those two bolts on the side.
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    It looks like an NP200 or 201, they were used before the 205. I believe it shares some common parts with the 205. I'm not real familiar with them but I'm sure someone else wil chime in with more info.
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Looks like a NP200 or 201? No tag on the back threw me off but I was thinkin maybe a divorced 205
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    The more I look at those photos and one of 205's on the net... That t-case looks to be larger overall than a 205.
    And AK got the term I was looking for... "Divorced".. DOH! :P
  6. AkMudr
    Dec 30, 2004
    917
    Alaska
    I really wanna say divorced 205 but theres no idler gear cover on the backside which makes me also think its a 203 :blush:
    Mot likely Chevy, the fornt output is on the pass sid eof the case.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Doesn't have a reduction box so I dont think it is a 203.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Nope, not a 205. It doesn't have the 3 bolt shaft cover on the back and the "things" that move in/out to shift gears are in the wrong spots. And it doesn't look like what's in my truck.
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    chevy never made a divorced np203, thats a ford-only item. too bad i can't see the pics, or I could help more.
    EDIT: does it have a really huge PTO cover thats way different than the one on 205's and 465's? uses something like 8 or 9 bolts...
    if it does, then its a NP202 from an International.
  10. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Not a 205
    Not a 203
    The PTO cover is wrong to be 205 for one thing. Also all of the above comments
    There is no AL reduction box so no 203.
    I think Atho has it right 202?
  11. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Yes, the pics show a PTO cover that looks to be twice the normal length. It's very long. I believe you are the winner. :D
  12. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yes it has the bigger pto cover with 8 bolts
  13. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    well I did a little more digging...if it has a drum ebrake on the 2nd rear output (which no one has mentioned, I figured they would if it was there) then its a NP200 from a Dodge M37 or Jeep M715.
    If it doesnt have the ebrake, its most likely a NP202 from an International. Could also be a NP201, but they are way older.
  14. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I think it's an IH NP202 also
  15. divorced
    Jul 20, 2004
    5,115
    Me - Are you sure that you have a 205? It doesn't look like one to me.
    Seller - It is a NP 201/205 everything is the same inside, the rebuild kit is
    the same for the NP 201 and NP 205, theres no differcts other then the
    looks
