What Temp??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Jun 5, 2001.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    I was just wondering what temp range ya'll were runnning in? I run about 210 without the A/C on and about 220-230 with A/C in 90 degree heat. Is this normal, because I am worried with summer coming and temps in the 100's here in Tx that I will be running too hot.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Thats about right. If it gets over 230 you may start running into some problemos.
    Just make sure your anti mixture is good and your fan is working properly.
    I run right at 210 220, but I dont run the air, less the wife is with me.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Also, you may want to get some soap mix that you can spray from a bug spray dispensers and spray in on the radiator and wash it off real good. Having clean coils helps alot too. Same as having you home Air unit cleaned every year.
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    My truck runs 210 with no air, and a little more when first warming up. that is with the factory electric guage with new sender, but we all know about the "great" factory electric guages. Just tell ya'll.
    Ben 87 Jimmy
    <A target="_blank" HREF=http://www.bens87toy.coloradok5.com>http://www.bens87toy.coloradok5.com</A>
  5. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Wow. Mine runs a tad under 190 degrees and that's because it the weather has been over 100 degrees here for the past month!
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Mine runs about 180 in stop/go traffic in Tucson. About 210 withg the a/c on. I run a 165 thermostat tho. Going to move to a 190 to see what happens.
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Damn jimmyjack, my wife is in Tucson as we speak.
    But back to the temp. Mine has ran at 210 since I have owned it. Even off road and in traffic......its always at 210.....
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Uh...at the second line from the left.
    '71 Blazer CST with alot of rust
