What the best u-joint?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bennett, Dec 17, 2000.
  1. bennett
    bennett Registered Member
    Nov 12, 2000
    45
    what do you guys suggest as the best u-joint - I have a debate going on with a fellow worker as to which are best.
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    SPICERS!!!!!!![​IMG]
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Spicer(Dana) 5-153X
  4. Hobbes68
    Hobbes68 Registered Member
    Mar 20, 2000
    80
    Yonkers, NY
    Spicer all the way!!!! I had a driveline vibration that was caused by using other brands of U joints (had to replace one in a pinch and had to settle for the parts store brand). You could actually move the driveshaft side to side after it was all together.. Went away when I put in Spicer's.
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    Hey boys the original spicer was good- but now spicers 5-153x is a neapco look alike- you only get the good stuff using the oem now- 5-625x non greaseable- if you ask me thats a crock - spicer is messin up to say it nicely-
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Say it isn't so drivelineman!!!!???[​IMG]
    Damit I hope they don't sell out on us!!
    I'm gona hit ALL the local shops and stock up on the real deal!!
    Hey anyone ever try the Summit Alloy "heat treated manganese alloy steel"???? Does all that fancy talk = TUFF STUFF or just HYPE?????
    http://www.burt4x4.coloradok5.com
  7. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Burt4x4,
    I haven't tried it bur supposedly they have a lifetime warranty.... That would be nice.
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  8. Hobbes68
    Mar 20, 2000
    80
    Yonkers, NY
    Ya but how good is a warranty when you're stuck on the side of a trail with a broken U joint and a bent driveshaft???????
    Are they greasable?
  9. Executioner
    Feb 22, 2000
    1,530
    I hope not, but its a new milliuim, so anything is possible.
    Where you getting yours, from Tenn. at the factory, or from a DIST. /Wahrhouse ?
    Whatch out for "Gray Market Product" !
    Spicer would be rolling over in his grave.....................................
  10. Jeff 86K5
    Jeff 86K5 Registered Member
    43
    Kentucky
    This is a post I've been waiting to see. My Blazer goes through at least a set of u-joints per year. I also have a vibration up to about 45 MPH then it smooths out. I have been using a greasable type I don't know what brand, and I've been greasing it every 3K miles.
    Maybe all I need is to buy the Spicers???
    Which is the best? Greasable or non-greasable?
    My Blazer is an 86 w/ 350, 700R-4, 3:73 gears so are these part numbers for my application? 5-153x & 5-625x?
    Thanks for the help.
    MERRY CHRISTMAS
    Jeff 86K5
  11. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The best ujoint is the one that comes with a lifetime warranty.
    AUtozone sells non-greasable 'Brute Force' ujoints, lifetime. I have not had one fail yet, but if I ever have any problems, I can get new ones!
  12. drivelineman
    Aug 23, 2000
    707
    yours is the 2-3011 neapco or 5-3147x spicer we hope anyways- and its called 3r style- there not great for angle and big tires - but the good news is it can be upgraded to all one ton easily give me a ring for a quote- 530-872-5725
  13. drivelineman
    Aug 23, 2000
    707
    Mike that's actually a neapco joint and the parts stores sell you on the lift time deal- i gues we are all suckerd in from time to time- they will sell you oil - spark plugs etc every time you go to waranty your life time joints- if it works for you then do it- jesse
