what the F
Discussion in 'The Garage' started by ChevyDan, Mar 1, 2006.
  1. ChevyDan
    ChevyDan Registered Member
    Dec 8, 2004
    44
    Ballston Spa, NY
    I've got a 1988 oldsmobile cutlass supreme classic, 307 4bbl.. I am 1200 miles away from home, and need to adjust my timing, I've got a light but can't figure how to get the distributer loose to adjust it. Yes, I am a retard. :D Please help, thanks
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Won't a regular distributor wrench loosen the clamp bolt?
  3. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    Yep a 9/16 ditributor wrench should work. If the distributor is frozen you can grab the base with some big azz channelocks and break it loose.
  4. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    strap wrench..
    I used an oil filter strap wrench to loosen a stuck distributor once..most GM HEI distributors have a square block cast into the housing above where it goes into the block..you can grab it with an adjustible wrench there..:crazy:
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i had a 307 out of an 87 Olds wagon, tried to pull the dizzy when i blew the motor, so i could put it in another engine. a pipe wrench and a cheater bar couldnt budge that thing, so i junked it all.
  6. ChevyDan
    Dec 8, 2004
    44
    Ballston Spa, NY
    Thanks Guys, The Channel locks worked.. I was scairt I was going to F someting up, but it came out okay..
