What the he_ _ is wrong with my wipers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WILL, Apr 15, 2001.
  1. WILL
    WILL Registered Member
    Feb 4, 2001
    44
    Indiana
    My wipers are really freaky, they work when they want and dont turn off sometimes. Does anyone know how to solve the problem and where to get the parts at the best prices? Thanks
  2. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i just replaced my motor and pump, they were doing scaaaarrrryyy things. now they work great!
    but i have heard that replacing the motor does always help. the mechanism that is under the cowl/dash can sometimes bind.
    Knife.
    knife.coloradok5.com
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It could also have something to do with the wiring that goes through your steering column. I had a short at the pivot point on my tilt column- the coating had worn away and exposed a couple of the wires. My wipers started acting like yours and then one day...............<font color=red>POOF</font color=red>!!!!!!!!!!!!!............the whole harness melted out. I lost my wipers, my cruise control, and around $300 in parts and labor to get everything repaired.
    If you can rule out a bad wiper motor, take a look at your wiring and make sure that everything's intact and there's no wear on the wire coating. If you fry your column wiring you're in for a major headache.
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Every once in awhile mine crap during a good rain shower. It turned out the fuse was corroded. I sprayed some contact cleaner in there, gave the new fuse a little twist and all is well,,,, Its worth a shot.
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
  5. K5blazer
    K5blazer Registered Member
    Feb 8, 2001
    12
    My wipers were the same way, staying on and all that crap. Put in a new motor and they work great.
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    HAHAHAHAAH!i was bragging about not having phantom wipers earlier today,and guess what!?!i turned them on they went to the top and stopped!!!i find it hillarious myself.but ive got a weird sense of humor[​IMG]so now theyre stuck straight up.ill look into it.
    PURE INSANITY
    86 blazer see it at:<A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292792569>http://www.zing.com/album/pictures.html?id=4292792569</A>
  7. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    Mine had a problem with not turning off. Turn to the mist position and they would turn off. Went like this for years until the switch crapped out and now has no positions. In the process of trying to replace the switch which is a real bear. Hopefully this will solve the problem and nothing else is wrong.
    90 GMC Jimmy, 350 TBI, 700R4, 32's
    84 Bronco II 204,000 miles and counting...........
