what the heck happened
Discussion in 'The Garage' started by hunterguy86, May 1, 2005.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    So I went muddin yesterday. On the way back to the house, the k5 suddenly started to idle up really high. I kicked the throttle and it came back down some. Today I pulled off the aircleaner and looked, and all looks fine but still ran way too high. So I got a torque head screwdriver and idled down the carb. What caused it to do this? Am I gonna screw anything up by turnin down the carb? What else should I do?
    My ride is an 86 k5 w/ a 305/700R4/np208. all stock.
    On a side note how can I post up the video of the muddin trip?
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    That happened to me when I got mud all over my carb. I just doused it down with half a can of carb cleaner and worked the linkages while I cleaned it out. Then I put a little WD40 on it, and worked it in. Everything was fine after that. Also, check to make sure that your fast idle cam isn't sticking. Mine used to do that sometimes, but I just made a small adjustment to the choke pull off and it's fine now.
  3. 84blazin
    84blazin 1/2 ton status
    Nov 9, 2004
    345
    Queen Creek AZ
    That happened to me also. My choke terminal broke off. Right now the chokes zipped tied open till i go an replace it. :D
  4. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    After idleing the carb down it seems to run better. I think the idle was a touch to fast in the 1st place. I sprayed a bunch of carb cleaner in and on the carb and linkages ect. and now it seems to run ok if not a touch to slow.
    Thanks for all the help.
    How can I post the video of the muddin trip? Can somebody host it for me?
  5. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Someone can. I think maybe whiteknight, I'm not sure.
