What the heck is causing this?
Discussion in 'The Garage' started by hunterguy86, Jan 1, 2006.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Well I got my lift put on this weekend. I installed 4inch front lift springs, 4 inch rear blocks, new shocks and a raised steering arm. Now between 25-45 there is a vibration. once you hit 50-55 it goes away. I also noticed today when I was driving when you let off the gas there is a loud grinding sound. What would cause these issues? What should I check?
    Thanks for the help yall
  2. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    the vib sounds like a drive line vibe,
    did you get tappered blocks or shims?
    when you lift it you change the angle and you can get a vibe in a certain speed range,
    go to harbor freight or sears and pick up a cheap angle finder and find what angle the pinion is in relation to the yoke on the t-case.
    some one will chime in on how many degrees difference it can have
  3. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    You, my friend, now have bad pinion angle. The sound that you're hearing is driveline vibration. There's a great explanation of the whole thing here: http://www.4xshaft.com/driveline101.html
    Basically, you're going to need to angle your pinion upward to solve for the bind you've put it in. You can do this with degree shims, beveled blocks or rewelded perches. A CV joint at the transfer case probably isn't a bad idea either. The bad news is, more work/money. The good news is, nothing catastrophic and a relatively easy fix.
    Good luck...
  4. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
  5. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    I had the same issue when i installed my shakle flip.
    I lowered my transfer case and the vibe went away.
    Unbolt the crossmember and take the 3/4 inch spacers and put them between the crossmember and the frame. vibe no more:D
    Also, Get rid of the blocks and do a flip. You will love the ride.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Yes, driveline vibration. When you are slowing down, hit your break really hard and see if the noise gets alot worse. If so your yokes may be making contact.
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    If your blocks are tappered make sure they are in the right way. The thicker end of the block goes towards the rear.
  8. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    The blocks are tapered and the thicker part is towards the rear. This shouldve angled the pinion back up enough but I guess not. I was under the impression that 4 in of lift wouldnt change things that much to where I would have to rework my shafts.
  9. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    well i had that vibration when i put my 6'' lift on . i would try to move the spacers on the crossmember to lower the transfercase if you have not allready , that worked for me .
  10. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Well I figured out what the noise was. I was lookin at my pinion angle today and it didnt look to bad. and then i looked at the tcase and noticed it was leakin from the front output shaft seal. Then i checked the tcase and it was low on fluid. So I changed the seal and filled it back up and that fixed it.
