What the heck is it called...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Mar 23, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Well it is that cover of some sorts that looks like plastic that covers the flywheel and mounts on the bottom of the tranny.
    Mine is hanging on and the prev. owner tried to just add bigger and bigger and bigger washers to hold it on.I want to get a new one but what's it called ...... Thanks for the info ahead of time.mike
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    It's called an inspection cover...some guys call em dust covers. It's just supposed to keep the crap out, but sometimes holds the crap in...like gooey mud./forums/images/icons/tongue.gif
    Rene
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Thanks for the info I thought thats what it was but not sure /forums/images/icons/smile.gif So is there any benifits for them or against them.
    Other than the mud factor.Will it kill the tranny If it isnt there,that type of ????'s
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I've always run one...but I avoid mud. The guys that like mud seem split on whether it helps or leads to problems.
    Rene
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    A friend of mine removed his and ran over an old barbed wire fence and the wire got sucked up and wrapped all over around and throught the fly wheel. It was a freekin mess!!!!
  6. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I think that cover was originaly cast aluminum and had a couple of strut rods mounted on it. The plasic one is pass car
    or 2wd.
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The torque converter inspection cover came in three different styles, plastic, sheet metal, and aluminum. The plastic and sheet metal ones are for passenger car while the aluminum one is for the K case truck. Make sure of which tranny case you have before you go and buy a cover, the passenger case uses 4 sheet metal screws to attach it to the trans while the K case truck unit uses 6 bolts to attach it. The passenger case can use either the plastic or sheet metal while the K case truck can only use the aluminum style.
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> The question is , where do you get one that will bolt right on without having to trim it with snips to fit around the starter ?
  9. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I got mine from GM for $20.00 I think?
