what the HECK is this ? *pic posted*
Discussion in 'The Garage' started by uglychevyZZ4, Sep 13, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    All i know is it is some kind of dual carb setup, but is it a webber or offy or????? it has what looks like in the back to be ports for either a 2 / or 3 cylinder mifold. it is foriegn i think either way if i knew what it was from or was, i could sell it
    /forums/images/icons/grin.gif [​IMG]
  2. Grim-Reaper
    7,385
    Atlanta
    It looks like a set of side draft webers off something like a MG or Sptifire. Might be a set of solex's (sp)
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Look around on it for a Nissan in the casting.I had a dual setup like that that I got off of some Datsun Z car.
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Those are Hitachi side draft carburators which came on early datsuns like the 240z. I converted a Porsche 924 over to those using a 1980 Yamaha 850 Special exhaust pipes as an intake manifold with great success. Bosh fuel injection went out on a free car when I was a kid, so.. don't ask!
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    "What the heck is it?"
    You got me by the nut-sack!! /forums/images/icons/tongue.gif
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    are they good for anything? worth a darn CENT? /forums/images/icons/grin.gif
  7. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Well a friend and I in high school metal shop made a sheet metal intake for his VW to run those carbs .(No,Im not kidding)
    Im sure you could figure out some way to run them on yer K5 /forums/images/icons/grin.gif
  8. fred79
    fred79 Registered Member
    Aug 14, 2002
    12
    Pittsburgh ,PA
    i don't know what they are for but that looks like a propane regulator on the very top of the setup o rit could be a vacuum selenoid
  9. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Not likely, im thinking e-bay, but i have no idea what its off of, and what years, ill go look for numbers now ok, ill post what i find.
  10. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Cant be off a Z car. IIRC they were all 6 bangers.
    Ill have to agree w/ Grimmy. MG or Triumph. Ill look in the morn at the MG and Datsun 1600 we have at the shop. And Ill take a look at the TR7 motors dad has at the house in storage before we go to the shop. If I cant ID them from what we have that I can look at, Ill have my dad (30 plus yrs as an import mechanic) take a look at this post while were at the shop.
  11. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok, and i saw your post in wanted section and for W.I.W : i think that sux dude had you sit on that lift then hosed you for 4wpw /forums/images/icons/mad.gif
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Only the Brits could come up with a piece of work like that.
    I'm pretty sure its SU carb setup off a mid 70s or later MGB.
    The EGR valve shows its off a smog engine. I dont know what its worth. They didn't perform well. They are a nightmare to tune and keep that way.. A lot of perple just yanked them off and put on dual Webbers.
  13. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yeah they were off a 240Z, they had dual one into three intake mainifolds for the straight six. The black tops on each one are where you add oil for the hydraulic the vaccum controlled secondaries.
    Quote
    "The 240Z was different from the open cars, sharing only its assembly plant and the sugar-scoop headlamps. Rather than the U-series overhead-cam four-cylinder used in the 2.0-liter roadster, U.S. Z cars got a lengthened version of the 510 sedan's L-series, aluminum-head engine. The 2.4-liter inline six shared bore and stroke, rods, bearings, valvetrain and a duplex chain-driven cam with the 1.8-liter four that powered the 510. With higher compression pistons, larger intake valves, more radical cam timing and a pair of Hitachi-SU sidedraft carburetors, it was rated at 150 hp at 6000 rpm, with a 7000-rpm redline."
    I used to have a Kit car based on a 240.. loved that car even more than my 510 but theres really no replacement for displkacement. The handling was fun though.
    You can buy them new too at http://www.zparts.com/ads/restoration/restore_index.html
  14. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    They are fun and a novelty at best for a small displacmeent engine. There require frequent tuning and eat oil. They performed well at high rpm though but were a pain to keep balanced.
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    looks like the MGB stuff to me too
