What the heck was in my diff?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Mar 31, 2001.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I replaced the 80/90w in my rear diff today. I hadn't done it for a couple of years and couldn't BELIEVE the slop that was pouring out of there. It looked like a chocolate milkshake, all frothy and brown. I managed to clean the inside up pretty well with the help of a can of Brake-Kleen, and everything looked good- no wear and very little shavings on the magnet. Does anybody know why the fluid looked so ugly? I don't run in the mud, and can't remember the last time I had water up past the axles..............
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Water mixed with 80/90, Water gets everywhere!
    Twiztid
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Is the vent hose still there?
    90K5
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    POSSIBLY condensation if you dont bog or cross water.consider your self lucky the last time i pulled a diff cover the pinion seal went bad and toasted the diff(things get real ugly real fast w/ no oil)all i got out was ground up diff in what used to be a little oil left in there and big chunks of ring&pinion.was a good excuse to upgrade tho.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.
  5. Can Can
    15,552
    136
    The vent hose is still hooked up and the breather cap is still in place...............Could water be finding it's way in somewhere else?
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Everywhere else, that stuff is almost unstopable! If you put your hot axle in the drink and it cools off faster than the vent can can breath then it will suck some water or air in from somewhere. Not a big deal if you keep a eye on it. I pulled the same milk shake out of my diff too and haven't done a water crossing since the last time I changed it, have no idea where it came from, but it was there. Check the the vent tube, the breather cap could be gummed up and clogged. A check the axle seals (while your there check the shafts for a groove)
    Twiztid
  7. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    If your vent tubes are up high, then it's probably your axle seals.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  8. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    if you dont cross water,or bog,your vent tubes are in tact,its prob condensation.think of a can of pop,the outside gets wet,becuz its cold in there,but its hot on the outside,just w/ a diff its inside out.hot inside cold outside,esp.if your up north. you dont see the condensation like a can,cuz,its inside.if your axle seals were bad,most likely youd find oil in your brake drums.water will go everywhere if given the chance.if theres no chance,its prob condensation.IMO.does anyone else agree????
    PURE INSANITY
  9. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Just swap your diff oil occasionally.
  10. dyeager535
    26,976
    I'd have to agree, thats just normal. Nothing to worry about.
    Dorian
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, it could be going past your axle seals or you may have a hole in your vent line.
    I pulled the plug out of mine once and that milky brown stuff came shooting out at me!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    " Ah.. Hong Kong, home of shiny green suit!"
