what the heck!
Discussion in '1982-Present GM Diesel' started by savagek5diesel, May 4, 2004.
  1. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    you know, since i bought my truck, the little things that you might usually expect to go wrong do, and you fix them in a hour or so, then the big things start going wrong, then the expensive things. But what pisses me off most are the annoying things. And here's my question.
    Mmk, i have an 83 6.2 jimmy, the starter bolt closest to the drivers side had the threads pulled out of the block, not cross threaded, but simply came out with the bolt, and now the bolt doesn't thread completely into the block, and the same thing happened to every flywheel cover bolt, so now my flywheel cover just hangs out on top of my tranny cooling lines and it rattles with every bump. Is there any logic behind this? only thing i can figure for the starter bolt is that when napa gave me the incorect starter bolts, or over torq'in them down. Also, does anybody have any ideas for fixing any of these two problems?
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Heli-coils work best for that kind of problem...or if the remaining hole is too large an insert might be better. Do you run the correct starter brace?
    Rene
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Sounds like they were heli coiled first and you unthreaded them ? Just my 2 cents /forums/images/graemlins/dunno.gif
  4. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    yeah, i think you're right, because theres like 6 of those little coils sittin' in my tool box now. thanks for your input guys!
  5. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    1982-99 (all 6.2 and 6.5) Starter Bolts & starter bracket
    GM 15544950
    1982-88 6.2L Starter Support Bracket only
    GM 14028931
  6. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    Yeah, I highly recommend that starter support bracket.
    I stopped on day for lunch. Came back out and tried to start the truck and the starter just spun like there was no flex plate. Crawled underneath, and the rear most starter bolt was broke off at the block. I didn't have the support bracket. /forums/images/graemlins/eek.gif
  7. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    Do the 24v starters use the same bracket?
  8. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    As far as I know the bracket should be the same. I know that the starter looks the same from the outside.
  9. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Does anyone have a picture of how the bracket attaches. I have the bracket but can't figure it out.
  10. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    does someone have a pic of the bracket? i need to see if I have one.
  11. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    Well I don’t have a picture of the bracket, but I can walk you through the install. The long slot is where the back bolt on the starter goes, it is held on by a nut. The other hole is pointed up and is bolted on to the engine block. Hope that helps. /forums/images/graemlins/thumb.gif
  12. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I will take a look again and see, just couldn't find where it went the the block.
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If I get some time tomorrow and can see it through my cam I will take a pic for you.
    If not I will give you measurements and descriptions so you can find it.
