what the hell is wrong?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 74K5Jay, Dec 9, 2000.
  1. 74K5Jay
    74K5Jay Registered Member
    Oct 17, 2000
    20
    Fort Worth, TX
    My motor only has 8000 on it and since the cold weather it tends to die sometimes not all the time. Well anyway its gradually been running worse and now it won't even idle hardly. If you give it any gas it backfires through the carb. The thing is motor, carb and everything including ignition was all new at the same time. i took the carb off tok it apart cleaned it (nothing looked wrong) new plugs, cap, rotor and it still does the same thing!!!!!!!! The carb is edelbrock #1406 (350 motor non-emissions) I sprayed carb fluid around the intake and carb to see if there were any vacuum leaks but didn't find any. I think the problem is the carb. What do you think?
    DOES ANYBODY WANT TO BUY A CARB!!!!!!!!!
  2. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Check your ignition wires, I had a set of Accel (crap) Super Sport wires on my Jimmy. I would get backfiring and an odd erratic idle now and then, also have a 1406 Edelbrock. I was starting to think carb as well. I finally changed my 1 1/2 year old Accels out for some 8.5 mm spiral core wires. Presto![​IMG] its never run better!
    Rene
  4. rebel222
    rebel222 Registered Member
    Aug 21, 2000
    58
    Louisiana
    Sounds like the carb to me. How old is it? Check the fuel filter/pump, could be a clog in there. Also try the sending unit on the gas tank. Sounds like gas isn't getting there. Check the needles on the floats. Let us know what it is.
    Logan
  5. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
  6. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Did you check your timing? Maybe it got bumped or loosened off and moved on ya?
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
