What the hell would cause this? ANYBODY?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wally81k5, Aug 31, 2003.
  1. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    SMoke!
    My truck only smoke a bit, but it's after i have been stopped for a minute or so at an idle. Just smokes for 3 or4 secs as i drive away?!
    And at that it only does it sometimes!>?
    Help.
    87 tbi 305!?!?!?
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Re: What the hell would cause this?
    Sounds like valve guides or seals ???
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    What color is the smoke? Blue, white, or black? Once you figure that out it will give alot better idea of what it could be.
  4. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    I agree with the seals.. Use the premium ones for replacment, and don't forget the little 'O" rings that seal the spring retainer to the valve stem.. they are usualy the culprit..
    Old hard intake gaskets can do it too. leaks oil under high vacuum from inside the lifter valey.. Use OEM gaskets only
    /forums/images/graemlins/truck.gif
  5. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    okay, heres the thing, i just replaced the valve seals!
    Now what?
    I thought maybe the 5w30 was a but to low for summer so i swapped in 10w40, but it still does it!??
    What do i do?
  6. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    Are any of your plugs getting fouled by oil? that burn off can cause it to smoke like that for a few seconds. Mine does the same thing.
  7. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    No, my plugs are okay. It doesn't happen enough to foul them, and i need to know where the oil is coming from to stop it.
    I have heard of people hearing of this! so someone at ck5 must know!
    I guess i could giver the old can of no smoke!
  8. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    It may be fuel. I have a choke gone bad on my Quadra-Jet, and that thing smokes for about the first 30 seconds to two minutes when I first start it(dependant on ambient temp.), because of the rich fuel/air mixture. Black smoke=gas, blue smoke=oil, & white smoke=coolant. Hope this helps.
    John
