what the hell?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73/75 k5, Apr 12, 2000.
  1. 73/75 k5
    73/75 k5 Registered Member
    Mar 18, 2000
    38
    ca
    today I went to check my fluid level on my 205 transfer case and when I pulled the filler plug out, out came a gushing flow of tranny fluid. Do I need to rebuild my t-case or tranny? Did possibly a rear seal bust on my tranny? Help! This is the first time I've seen this.
    Any info would be greatful
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I use ATF fluid in my Transfer case. Its a NP205.
    Dexron III was the type. NP205 is suppose to use ATF fluid. That is probably why you had it in there.
    Boss
  3. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    I may be wrong but i thought a Np205 used gear oil? My Np208 used ATF and so did my Np203. Anyone know for sure?
    And if it is pouring out of the fill hole it sounds like there is a problem how would you fill beyond that point?
  4. dpearson
    dpearson Registered Member
    Apr 10, 2000
    95
    El Paso, TX
    Are you sure it is supposed to be ATF in the 205, I have heard it both ways. Need to know for sure?
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    My 205 uses 90WGear Oil!
    Rock ON![​IMG] 72 K5 [​IMG]
  6. Boss
    2,550
    Maryland
    ok, I didn't read it right. I didn't see the part that you said it is gushing out your filler hole. My bad, now that sounds like a problem. I would assume your tranny is leaking into your transfercase. But I hear it does leak from time to time and that is ok if small amounts b/c the NP205 uses ATF. And YES, it is suppose to use DexronIII. formerly Dexron II. And YES, you can use gear oil too.
    Now, for IDGMC, man, you put ATF in your NP203??? NP203's are suppose to use Motor oil, not ATF. I'm am almost 100% on that, but I do not own a 203 so I can't back it up. Someone correct me if I'm wrong.
    Boss
  7. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    NP203=motor oil
    NP205 w/MT=gear oil
    NP205 w/AT=ATF
    NP208=ATF
    NP241=ATF
    Your transmission is probably leaking into the transfercase. You can fix that seal or you can regularly add ATF to your tranny and drain some from your transfercase.
    CB
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Yup, the NP203 uses 10W-30 engine oil. I have one still full time on my Blazer. Over 105K miles and still running fine.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  9. I know I'm not answering but, where exactly is the filler plug for a 203?
    <font color=red>ABO</font color=red>
  10. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    Stupid question, but have you checked your tranny fluid level now? If the fluid came gushing out of your t-case, and your tranny is still reading full ... ??
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
    thunderdog@metallica.com
  11. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Motor oil in a 203? Oh Boy I need to check and see whats is in there. I think its gear oil.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    http://79blueknight.homepage.com
  12. dpearson
    Apr 10, 2000
    95
    El Paso, TX
    I bought a used 205 without oil. It is going behind an Automatic, are you sure I use ATF, it currently has gear oil, will either one be bad for it?
  13. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    You can run either ATF or gear oil in the NP205. If your AT leaks a little into the transfercase then it would be better to have ATF in it. Otherwise you would be mixing ATF and gear oil.
    CB
  14. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I really like gear oil in mine more than ATF... Ive never heard of anyone running tranny fluid in one so Im sticking to what the majority uses!
    Mike'
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  15. Boss
    2,550
    Maryland
    Gear oil is fine, but ATF is better. Dexron III is the preferred choice. B/c your tranny will sometimes leak into the transfer case, so why not have ATF leak into ATF instead of ATF leak into Gear oil.
    Boss
  16. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    I had this problem start on my NP 231 after my transmission was replaced (S10 Blazer), turns out that the input seal in the transfercase started leaking after the transmission was pulled out and reinstalled. It is probably the input seal on your transfer case. relatively simple job.
    '77 K5
    <font color=red>mudfanatic</font color=red>[​IMG]
  17. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Just to add my two cents, the 1974 Factory Service manual calls for 30w in a 203, not 10w-30, its supposed to be a straight weight not a multi-weight
    RaisedK5
    "Friends don't let friends drive Fords"
  18. Blazer79
    1,816
    The filler plug is on the rear of the case, to the right of the rear driveshaft output (your right hand if you're facing the rear of the transfer case). It's a large plug (9/16" maybe?) that you can't miss. It's a little high in the case. Just fill it up until the oil starts to pour out.
    There's no plug to drain the old oil, so you'll have to remove the lowest bolt of the ones that are in a circular pattern. Remove the skid plate in order to prevent a (even larger) mess.
    I won't take credit for that. I learned it from some wonderful guys at a wonderful site called ColoradoK5.
  19. Blazer79
    1,816
    I visited Shawn's link about oils. Now I know that 10W means that it will be like a 10 grade in Winter. Since I'm in hot weather, I think that the oil will act as 30 grade most of the time, so I guess I'm safe, or not?
    Does your manual mention anything about how often should this oil be changed?
