what things to check on junkyark axles?
Discussion in 'The Garage' started by GMC500, Dec 19, 2006.
  1. GMC500
    GMC500 1/2 ton status
    Aug 19, 2005
    203
    Safwa
    today I found a 1980 gmc 3/4 ton burb with 14bff rear and 10 bolt front with manual locking hubs
    it doesn't have a RPO sticker so tomorrow I will open differential covers to see what gears it has
    did GM offer 10 bolts on 1980 year or this was replaced ?
    and what other things should I check also ?
    the guy wants 1000 saudi riyals ( about $266 ) and that was the best price I got
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    there should be a ratio tag bolted to the cover. That price isn't bad if the gears are good.
    try and get him down to 940 riyals.:D
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    just stay away from 84/85 14FF's, they have the small pinion support bearings. also if there is a extra over-load helper spring its probably seen heavy use and has been stressed. I have seen a truck with two full spring packs hacked in place :eek1: :eek1: in the junk yard. ofcourse try and find an open carrier, not a gov-lock.
  4. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    which part of Saudi Arabia are you from??
  5. GMC500
    Aug 19, 2005
    203
    Safwa
    it doesn't have any tags from outside
    and regarding the price
    I will try to get him down to 900 or I will take the driveshaft + E-brake cable + the axles for 1000 - 1100 SR :D
    thanks
    I'll check that
    thanks
    I am from the Eastern Province
    please feel free to contact me @ safwaneez@yahoo.com
    Ahmed
  6. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    nice to know you ahmed,
    i am from Dammam and i think you might be from Safwa... right?
