What tire pressure do you run while wheelin'?
Discussion in 'The Garage' started by stallion85, Sep 14, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    What tire pressure do you run while wheelin\'?
    I have been dropping my psi by 2 each time lately and have gone down to 15 psi at the lowest. I run 35 12.50 Mtr's on a 16x8 rim. I have no top or doors on and was wondering if I went down to 12 psi if I would be pushing it. What do you guys run?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: What tire pressure do you run while wheelin\'?
    7 in the sand
    15 in just about everything else
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Never higher than 11-12 PSI.
    38.5x16x15 TSL, 15x10 wheel
    I have run 265/75R16 All Terrains at 6 psi before without beadlocks. Lots of grip to be had down there at the single digit pressures. /forums/images/graemlins/thumb.gif
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Hmmm, I would really like to take it down to 10 if i could get away with it. I have a full size spare and on board air...incase I bust a bead /forums/images/graemlins/thinking.gif
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    8-10... 39.5 TSL.
    j
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    16.5 wheels?
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    pffft... 15" rims. 16.5s are for ricers. /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
    j
  8. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    If I were you I would not go past 15 psi on 16 inch wheels. I run my 37 12.50x15 mt/r's at 12-14 psi on the trail, but I have 15 inch wheels. 15 inch wheels have a saftey bead on them which allows you to run them at lower pressure without worring about blowing a bead. 16 inch wheels do not have a saftey bead and therefore should not be run below about 15-16.
    -Harrison
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    ehhh, 16" wheels have a safety bead... its 16.5s that don't.
    j
  10. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I beg to differ, 16 inch wheels have a safety bead, my 589s do. i think you're thinking of 16.5's which do not have safety beads.
  11. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Plus the 12.50 on an 8" rim helps hold the bead, right?
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    generally. I have 15" wide tires on 10" wide rims. Seems to work ok.
    j
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I had this discussion with some of the AZ guys about my truck.
    I run 35x12.5x15 MTR's on 15x8's. I have been told by a few respectable guys who run MTR's (az-k5, therobzilla, FWP) that with the MTR's the majic number for the rocks is 17-18 PSI.
    After this the sidewall bulge to much and you start cutting tires. You also start to loose more and more clearence with the less amount of PSI you have.
    17PSI is the number for the rocks, lower for sand.
    This is 18psi. The tire is only suspended by the sidewall over a 2-3ft dropoff.
    http://community.webshots.com/photo/147853659/147858973UJvfqE
    http://community.webshots.com/photo/147853659/147859512vKcMxH
    If you are running 16" rims then you might get away with a little less PSI since you have a little less sidewall then a 15" rim.
    Harley
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Bias are stiffer so require less pressure.
    Radials at 18 PSI are probably about the same as a bias at 10-12.
  15. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    I run 8psi in the sand, arround 15 everywhere else. But i do have the Bias claws
  16. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thats why my friends with Super Swampers get away with running such a low pressure. I think I will stick with the 15 psi I have been running. It seems to do the job well enough. /forums/images/graemlins/pimp1.gif
  17. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I did some experiments on the hard concrete garage fllor a while ago with my 16x10 rims and 38x13 TSLs. I put a 4x4 chunk of wood on the floor and drove over it with one tire. At 15 psi, I could still feel the truck lift as it crawled over it. At 12 it still lifted a tiny bit, but at 10 the tire flexxed right over the wood with no lift at all. I ran at 12 the next trip, and it worked awesome. Of course, thats not much rocks... mostly muddy trail lines with logs to cross.
    So, generally, I drop them to around 12 or so for my wheeling.
    Mike
  18. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I run 35 psi, the mud that I play in doesn't care what pressure I run.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You might be shocked if you actually aired down.
  20. ugly_blazer
    Apr 12, 2004
    1,214
    I have never actually tried it, but I will next time just to see. The mud I run in (our lake) is soft clay and really has no bottom so I always figured that pressure wouldn't matter. I also run 16.5's, so I don't want to go too low and loose a bead. I've seen a lot of trucks loose a bead in the deep stuff with 16.5's. Maybe it's time for 15's? /forums/images/graemlins/thinking.gif
