What tire pressure to run on DD with 35's???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by triger, Oct 6, 2003.
  1. triger
    triger 1/2 ton status
    Jan 16, 2003
    177
    Budd Lake, New Jersey
    What tire pressure to run on DD with 35\'s???
    <font color="green">Finally have my truck on the road and don't know what to set my tire pressure at? I have 35's x 12.5 x 10's? I have them set at 32 psi but seem to hard. Any suggestions?
    T </font>
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Re: What tire pressure to run on DD with 35\'s???
    I run mine at 32 any less than that and my mileage drops significantly
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    With 35 inch BFG Mud Terrains on a K5, mounted on 10-inch wide wheels, I've found that 24 PSI up front and 22 out back keeps all the tread on the road so that they wear evenly. Higher pressures will give you better fuel mileage, but shorter tire life due to the centers wearing out. /forums/images/graemlins/cool.gif
  4. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Exactly what Harry said, but I run mine at 25-26 front and rear for even wear.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,074
    486
    Grand Rapids area
    Yeah, you will probably end up with something in the upper 20's. The bigger your tires, the less pressure you should run. The weight of the vehicle is fixed, but the size of the contact patch is increasing. Since you have more square inches, you need fewer psi to support the weight.
  6. triger
    Jan 16, 2003
    177
    <font color="green">Thanks guys...Trial and error I guess...Definitely don't want them to wear out to quick...Gas mileage is a bit of a concern but not too much...
    T </font>
  7. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    There was a post a while back about testing tire pressure by checking cold pressure, then heating the tires up and measuring again. Over or underinflated tires heat up too much and the pressures get too high. I think it was Grim that posted it
  8. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    Here it is
  9. triger
    Jan 16, 2003
    177
    <font color="green">Thanks for the post I will try that and see what happens...
    T </font>
  10. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I run at 22 lbs. any /forums/images/graemlins/thumb.gifmore are and I feel every ant I run over...
  11. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Harry,
    Is that psi measurement cold?
    What about your Burb? My 91V2500 has 6" lift and 35" X-Terrains............wondering what air pressure is optimum for a /forums/images/graemlins/burb.gif
