what tires measure up??my groundhawgs say 40" but they aint 40s
Discussion in 'The Garage' started by ilikeitloud, Apr 8, 2004.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    what tires measure up??my groundhawgs say 40\" but they aint 40s
    i measured them, only come up with 37.5" tall and still have good tread on em . but i was going to trade them in for a set of 39.5" TSLs and was wondering do they measure a full 39.5"?? do any tires for that matter??
    thanks matt
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: what tires measure up??my groundhawgs say 40\" but they aint 40s
    Every tire is different, but they pretty much invariably come up shorter than advertised, some by quite a lot! I hate lawyers and the "litigious society" but I would love to see a class action against all tire manufactures on this point. It’s definitely one of my pet peeves. As far as I can tell, it's pure false advertising any way you slice it. One good thing, it seems the new IROKs are actually fairly close to stated size (less than an inch smaller from what I recall) and I think they are fairly unique at that in the large off-road tire market.
    Anyway, seems like someone said those 39.5 TSLs were just over 38, but I don't recall for sure. You should be able to search and find the specifics if someone else does not have first hand knowledge.
  3. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    Most tires mounted on the wheels with the weight of the vehicle will measure short. My 38" Boggers on my Blazer are on 15x10's mearsure just over 36". My new 39.5" TSL's on my other truck on 15x10's measure right at 39".
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well Denman says 40" hawgs are 39"... but when you buy a set..they are approved for a 9.75 wide rim...hence if you go with a wider rim the tires are smaller... I am glad that my new 40's on 16.5x12 rims are 38.7" as NJ will only allow 38" tires through inspection now... I just wanted the wider tire ... even thought a 17x40x16.5 says 17" wide.. that measurement is from the tread on the sidewall all the way to the other side... thus the true width is 14".... all 38's are like 11" wide...so I wanted the wider stance for stabitity... but gonna have to /forums/images/graemlins/hack.gif after I lower the front 4" and rear 3" as I already would hit ... if I got to drive the truck!!!! /forums/images/graemlins/tongue.gif
  5. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    "well Denman says 40" hawgs are 39""
    what is that? tire math? /forums/images/graemlins/shame.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That measurement is called section width. It is measured from bulge to bulge. Draw an imaginary line through the tire from one sidewall to the other at the point where they are widest, and that's where they get that measurement.
  7. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Some friends of mine recently had the chacne to compare a 44" TSL, 42" TSL, 39.5" Irok, 39.5" TSL, and 36" MTR all side by side. The 44's were mounted on a 15x10 rim so that kind of screws that deal. The 39.5 TSL's were at 50-60% (17/32") tread. The MTR's, well who cares about those.
    Unmounted the 42" TSL's standing next to the Iroks were shorter. The 39.5" TSL looked like a baby to the IROK. The Irok measured 40 3/4". The 42" TSL measured 39.75". The mounted (8.75" Hummer Rim)42" TSL meausred 41". My Irok mounted on the same rim measures 40 1/2"
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I'd say interco is actually pretty accurate with tire sizing, my 39.5" TSL's measure 38.75" mounted and with the weight of the truck on them (19 psi). Sounds shorter than advertised...until you measure the circumference and it is 123.5". True diameter of the tire is 123.5 / 3.141 = 39.318".
    That is on a tire with about 75% tread left.
    Rene
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thats funny. My 42's, on 9.75" rim, about half tread, on the truck, measured 41"
