What to build with the parts-
Discussion in 'The Garage' started by misterfnygy, Dec 21, 2006.
  1. misterfnygy
    misterfnygy 1/2 ton status
    Jan 12, 2006
    199
    Reno
    Alright I have a dilemna- my original plan was to build a bad k5 from all the parts I have collected. Now I am starting to second guess that and build two nice trucks instead of one- but the blazer wont be as BAD. Here is what I got-
    1975 Blazer- runs but not real well
    350 with intake, carb and cam- has a valve rattle
    worn out 350 auto
    203 t case
    d44/12 bolt
    has 6" lift with double blocks in back!!
    needs a front fender and some paint but definitely buildable
    1974 1/2 ton pickup- torn frame at steering box, beat up body
    running 350
    465 manual
    205 t case
    10 bolts
    this will be for parts and maybe a trailer out of the bed
    1976 1 ton dually- really decent shape mechanically except for motor
    blown 400
    400 auto
    205 t case
    d60/14 bolt
    body is straight, very little rust- interior is used but works. would be driveable with new motor
    Extras-
    d44 8 lug
    14bff
    6" lift front springs
    4" rear springs
    383 stroker- need a few little parts but everything is brand new
    So if you had this pile of parts- what would you do??
    Build a big bad blazer- spring swap, d60/14bff, disks, stroker, 465/205- maybe doubler
    or keep the d44 in the blazer and build the 1 ton as well- 6" lift, stroker 400/205 etc.
    What do you think??
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    60/14 in the blazer, with the 465/205 (hell maybe even put the 203 in between them) add the 383, the 52s from the rear of the 74 on the front, with a shackle flip in the back.
    put the 350/400/205 in the dually (minus the dually fenders, maybe even with the bed from the 74 since its good enough to make a trailer out of) and put the 3/4 tons under it
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    What ever you do, you have to have this combo: 383/465/203/205/D60/14bff
    Also I don't think you should cut up the dually though...
    So swap the running 350 from the 74 into it and drive it as is.
  4. misterfnygy
    Jan 12, 2006
    199
    Reno
    both good options..
    good ideas- I just need to figure out how many trucks I need---
    The best part is that I have a total of $1600 into all the parts...
    Really cant go wrong!
