What to buy for new 60?
Discussion in 'The Garage' started by Txchevy18, Oct 15, 2006.
  1. Txchevy18
    Txchevy18 1/2 ton status
    Aug 29, 2006
    225
    Tx
    OK guys im fixin to make the leap to 1 tons. Im goin to pick up my dana60 this weekend, but its gonna need some work. Its a from an 82 chevy dually and is guted inside, the previous guy was usin it as a sfa and didnt need 4x4.
    So now I need to start gettin some parts together for the rebuild, but have a few questions 1st. Its going into a 86 k20 ,400hp 350/clocked 208 running 40" tsl's but eventualy 42's or 44's. I want to run chromo axles and possibly ctms and some kind of a locker since i have to buy a carrier newayz. Its a dd for now ill be running warn premium hubs and probally 4.56's so I dont have to regear the 14 bolt FF.
    Any suggestions as to what brands of shafts to run?
    Are the ctms worth the coin or should i just stick w/ "lifetime joints"?
    What locker?
    Thanx guys
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    don't forget about the issue w/ the wheels if you've already got wheels to fit your non-dually 14bt.
  3. 1976Blazer76
    1976Blazer76 1/2 ton status
    Apr 17, 2006
    552
    Ridgefield, WA
    Can't go wrong with running a detroit. Also with those tires I'd look into hydro assist steering too.
  4. Txchevy18
    Aug 29, 2006
    225
    Tx
    Ive already got a sky x-over setup and a hydro setup w/ a rock logic 1.5x8 ram and a 4x4 steering box tapped w/ a 2x4 sector shaft and wfo lines, bought it before i even had a 60. Im still stuck as to wether run h1's on my 40's or get new srw hubs from gm for $350 w/ rotors. I was thinkin a arb locker but have had very good luck w/ detriot as well. Just never ran one up front.
    thanx keep it comming guys
  5. 1976Blazer76
    Apr 17, 2006
    552
    Ridgefield, WA
    I've got the h1's, they look awesome, and ended up real close to stock width! :grin:
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    the new hubs are gonna have new rotors, studs, and races also. $350 is a good price. I work at a dealership and got mine for $320. If you are gonna run selectable locker, look into flanges/slugs instead of selectable hubs. they are a lot cheaper, harder to break, don't stick out as far. you probably already have them in the dually hubs now.
    I'm wheeling 44's on my 60 and haven't broken a stock shaft or u joint yet. I know its coming, but why spend a ton of money until I have to.
  7. Txchevy18
    Aug 29, 2006
    225
    Tx
    Ya im kinda wondering on my abilty to break a factory shaft too but, since i have to buy them anywayz y not save a lil more and buy the better parts and make it bulett proof. The reason i am considering slecteable hubs is so when using it as a dd i dont have the wear and tear of the rest of the parts moving contiuosly as well as less parts moving mean less drag on driveterrain and better mpg ( this is just an asumtion correct me if i am wrong). I drive on average 200 miles a week so this wont be my dd for long, just until i get the cash for a dodge 2500.
    keep coming guys
  8. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    yeah if you don't have anything now then get the good stuff. with slugs the axleshafts will spin. I couldn't even begin to geuss how much effect that has on fuel economy. I'm spoiled my ride to work is 2 miles. MPG is not a priority for me. You actually drive less then most people. the national average is 300 a week. wow is that is getting of subject.
  9. Txchevy18
    Aug 29, 2006
    225
    Tx
    Alright any guys any suggestons on what brand of shafts to run or are they all about equal?
    Thanx keep the comments coming
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I say you should run superiors and go 35 spline inner and outer. You are already running hydro so I would run slugs rather than hubs and also a Detroit. I say superiors as they are through hardened and induction hardend. Also with alloy shafts CTMs are the only way to go. If you break a joint you will most likely take the ears of the shaft out also. Not good when you are looking at $400 per side..
    Superior shafts, CTMs, Detroit, and Drive slugs all 35 spline:D.
    Ira
