what to do? I'm getting sick of this subject
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Feb 7, 2001.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    what to do? I\'m getting sick of this subject
    I am currently stuck on what to do. I have just chewed up my ring and pinion gear in my corp 10 bolt with 3.07 gears. I am running 33's with about 3 inch lift. I read some reviews about getting a 12 bolt. The Blazer is in the shop as of yesterday. The mechanic say's to leave the 10 bolt in and get 3.73 gears. I was looking into getting a 12 bolt used with 3.73 but nobody has one around Fremont, CA. One guy has a remanufactured one for $650. Should I just keep the 10 bolt re-gear it front and back, or get the 12 bolt? I'm short on $$$ so I'm sitting at home with no ride. I use the Blazer as a dailey driver/camping rig. I don't do hardcore wheeling or rock climbing! What to do? I'll be right back...
    <font color=blue> Taxes are Stealing</font color=blue>
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: what to do? I\'m getting sick of this subject
    If you are short on cash, just get new ring and pinion for the same gear ratio you had before. Stick with the 10B for now, and when more funds allow, get the beefier set up later.
  3. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    If you have the money available to you, go ahead and get the 12 bolt. I wish I could find a good 12 bolt around hear.
    Ike
    Spreading The K5 Gospel!
  4. dyeager535
    26,982
    191
    I've HEARD that the 12/10 bolt difference is slight..the 10 bolt has a thicker pinion or some such...personally, I'd put 3.73's or so back in it. But if you are going to be really hard on it, you are eventaully going to have to upgrade the entire axle assembly to a 14 or dana 60. I bet others are going to say the same thing : ) BTW, a cheap source of 3.42 axle assemblies is the mid 80's suburbans. They were a very common stock ratio then.
    Dorian
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Dude, just keep your 10 bolts and put 3.73 or 4.10's in there and be done with it. YOu are going to be looking at about 500 per diff to rebuild, parts and labor. Do the rear for now, then save and then do the front. PERIOD, END OF STORY. NEXT POST?
    Will work for beer, parts and tools.
    90 Jimi,350/700R4/241/10bolts/4.10's/33's/4"
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  6. UseYourBlinker
    Jun 7, 2000
    11,117
    Yeah I think I'm going to do that...Thanks for being straight with me guy's..
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Yeah it's not worth getting a 12B over your 10B, especially for $600. That's a little high. I wouldn't trade your 10 in on anything less than a 14FF, 14SF, or D60
    Durant, Ok
    I love my SAWZALL!!!
  8. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    for that $600 you should be able to upgrade to 3/4 ton axles.
    around here you can get a set for that from a private party
    and get better gears to boot. Most are 3.73 or 4.10.
    "IF YOU'VE NEVER BEEN STUCK.....YOU'VE NEVER BEEN WHEELIN"!!!
  9. Mud Bath
    Mud Bath Registered Member
    Aug 28, 2000
    84
    Wake Forest NC
    I had to replace my 10 b guts and it ended up costing me about 1K. Only thing salvagable were the axels. carraige and gears were toast. I changed from 2.73 ratio to 3.73. so the front had to be changed also. New gears were about 200 a set plus about 40 for the install kit. the carrige was about $400 (eaton posi). what a pain to buy and install. all thankz to West Coast Differentials www.differentials.com
    if you aint got tools dont buy it!!!!!!!!!! mb
  10. UseYourBlinker
    Jun 7, 2000
    11,117
    Yeah, so the shop is going to change the rear for no fee (my dad's buddy) then over the weekend my dad and I are going to try to change the front gears. What am I going to get into? Need any special tool's? step by step would be great...
    It's a stock 10 bolt with 3.07 gears changing to 3.73
  11. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I have a corp 12 bolt rear you can have for free just come over and get it
    Im in Colorado gear ratio unknow but if you need to know I could pull cover and
    find out.
    Bo
  12. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Blinker- I'm in Hesperia, CA. I know a guy in Fontana with 2 12 bolts. I was going to buy one for $250 or $300, I don't remember. Get a hold of me if interested and I'll go find out.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  13. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Hey Mud Bath, I gotta couple questions since i gotta have some inards replaced on my 10B.
    Did that 1000 include the axle shafts?? Or just stuff in the pumpkin. I got a quote of 800-1000 for just replacing stuff in the pumpkin (not even ring and pinion) and I think it might be a little high.
    I didn't get from your post whether or not you were happy with www.differentials.com. Was the good install stuff thanks to them or the pain from them [​IMG].
    Thanks!!
    <font color=blue>"It's just a differentialator....Totally unnecessary" [​IMG]</font color=blue>
  14. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    panther i would say that is very high
    s.smith 77blazer lookin 4 mud [​IMG]
