What to do with an old hub assembly (bumper)
Discussion in 'The Garage' started by jamber2541, Apr 6, 2007.
  1. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    Today I installed my bumber with a swing away tire carrier, What do you guys think?
  2. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    badass man...that's way cool
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Looks cool. Care to explain how you did that and what you used?
  4. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    3x6 rectangular tubing, 2 1/2 x 2 1/2 square tubing and some 2 inch round tubing, a 14b sf axle end, and an old dana 44 hub assy. A cut shaft is welded to the spindle through the back, cut and grind the extra metal around the hub, the spindle is welded to the 3x6 from both sides, the assembly gets put together just like the regular front hub does.
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I have seen that at trucks shows before. its a great way to build the pivot. the bearings are almost overkill for that application. the locking hub is great for holding the swingarm in the out position. Good job.:waytogo:
  6. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    That is a great idea.
  7. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    coolest new idea i have seen in a while, nice work
  8. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    started the front bumper today
  9. Big Blzn
    Big Blzn 1/2 ton status GMOTM Winner
    Jan 30, 2006
    3,587
    Orange County, CA.
    For your fron bumper did yu just get one long stick of 3x6 tube and cut if in the middle just 3/4 through and then bend to proper degree and weld the seam? In the other post it looks like there is a shallow "V" to the bottom side of the bumper? How did you do that?
  10. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    It was a long stick of 3x6 and I did cut through 3 sides, I tried the 3/4 cut but it was too thick to bend so I cut a little at a time and eventually found out that I had to cut all the way and create a tiny "V"
  11. BlazerBud
    BlazerBud 1/2 ton status
    Jun 14, 2006
    473
    Chattanooga
    Looks good, are you keeping it all gas tight to act as auxillary air tanks? I have those same gloves on the driveway.
  12. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Wow, I have been thinking of doing that for like the last year, I jsut dont have time to do it.
  13. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    It took me about a month, the front was easy I started last Sunday, worked on it yesterday and finished today, not really that hard but it was a PITA to move around.
