What to do with hookups for oil cooler when priming engine?
Discussion in 'The Garage' started by dawson444, Dec 24, 2003.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    When I am priming my engine on the stand, what should I do with the hookups for the oil cooler? Can I just plug them, or do I have to have a hose going from one to the other? Thanks!
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i would just temporaily put on a normal oil filter adapter while priming
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Ya just plug them or wait until you get the motor in the truck and prime the whole system. Also don't forget to flush the cooler. You wouldn't want all of that crappy contaminated oil in your fresh engine would you??????????? /forums/images/graemlins/thumb.gif
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    You cant properly flush a cooler. Its best to completely replace it. If you run a GM crate engine you are required to replace the cooler and flush the oil cooler lines to obtain a warranty. If you dont have proof that you replaced the cooler or flushed the lines you can kiss your warranty good bye.
