What to do with this tire?
Discussion in 'The Garage' started by MTChevy, Apr 15, 2006.
  1. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    I got these 35'' BFG mall terrains a while back and recently i just tipped my truck. 3 tires were still good but now 1 has a sidewall gash. This tire has less than 200 miles on it and I'm wondering what I should do with it? I sold off the 3 good ones but have this 1 perfect one with about a 1 inch sidewall gash in it. What do i do with it?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    tire swing
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Get a tube? Too big for an inside patch?
  4. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    tube isnt streetable is it? i remember a post poohbair posted where the tireshop wouldnt sell him a patch. where would be the best place to go?
  5. tweek
    tweek 1/2 ton status
    Aug 13, 2003
    353
    montgomery, ny
    a glass top, a few plumbing supplies and whala a table, the whole family can enjoy..............
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Not sure about your state but in California it is illegal to patch a sidewall of a tire. If it's a trail rig only i would put a patch in there then run a tube but radial tires are not supposed to have tubes in them.
  7. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    well thats the pits... 160 dollars wasted... if i had 35's id use it for a trrail spare but im going bigger now...
  8. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Yard ornament....
    I'd plant flowers in it...Lilly's would be appropriate!..:(
    A large semi-truck tire shop might be able to vulcanize a patch in it,but it will probably be difficult to get done anywhere if its illegal in your state..I've had a few guys do just that here,but the tires usually dont hold up,and could be fatal if used on-road..even OFF road it could be very inconvienient to have a tire pop while its flexed out to the max!..best not to chance it..vulcanizing isn't cheap either,usually its reserved only for semi-truck tires and heavy equipment tires...:crazy:
  9. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Did someone say Tire Swing?
    If you look at the tire, it has plenty of life left in the tread. I had a bad sidewall cut and I couldn't get myself to throw the tire away. SO I put it to good use.
  10. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    burn it:haha:
