What to do?
Discussion in 'The Garage' started by blazen86, Jan 6, 2005.
  1. blazen86
    blazen86 Registered Member
    Sep 8, 2004
    55
    Virginia
    I have an 86 blazer thats stock now and needs a rearend rebuild. I plan to lift it a total of 5 inches with 35s in the future. I dont think i want to go the DANA60 just because of the trouble to find one and rebuild it. But I was wondering if, since I am going to be lifting the truck in the future, if i should change the gears. I want more torque now, but I also drive the truck on the interstate so I have to be able to do about 70-75 preferably. So should I change the gearing or not? Ohh and if i change it in the rear, do i have to do the same up front? Thanks
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    you could find a 14bff for the price or less of the rebuild, most likley will have lower gears. and they usually come with a front 8 lug 10 bolt with the same gears. i got my set for 200 with both axles
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if you already have 3.73(highly unlikely) then you could find a 3.73 14 FF
    also 3.21 was put under some of these
    good luck
  4. blazen86
    Sep 8, 2004
    55
    Virginia
    so what came in them stock 3.21?
    ohh and were could I get a 14bff other then a junkyard (decent price that is)
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    dont even bother rebuilding a factor rear axle. Look around locally at yards, in the nickel ads, the paper etc... you'll find a cheap ff14b somewhere. It'd be a cheap way to re-gear too... just find a ff14b with 4.10s in it. Pretty common and then all you'd have to do is do a gear swap up front. And yes... you have to do both the front and the rear gears... unless you run different size tires front and rear...
    j
  6. blazen86
    Sep 8, 2004
    55
    Virginia
    one other dumb question
    what does bff stand for?
    Okay maybe two
    can i keep my same wheels? same lug pattern?
  7. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    GM corporate 14 Bolt Full Floating axle
    14 Bolts are 8 lug, so you'e either need new wheels or adapters.
  8. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    14bff stands for 14 Bolt full floating and dont get the 14 bolt semi float they aren't as strong.
  9. blazen86
    Sep 8, 2004
    55
    Virginia
    Were can I find an adapter?
  10. blazen86
    Sep 8, 2004
    55
    Virginia
    Anybody?
