What to do
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Jan 21, 2003.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    Guys I am tired of the GM saggy butt. I have a 2.5 inch lift with 33's and the back sags bad what should I do. It looks like if I lift the back it may pull out the driveshaft. I thought about taking a leaf out of the front, but it will rub and I don't want to trim what should I do. I guess I could get me a 502 to even it out.
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    id get some ORD zero rates, or some add a leafs. just loosen the u bolts and pop em right in
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Do you have saggy butt like this?
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You could do a search...but i like to type this so your lucky...is your lift blocks or springs? If its springs, do you have the old ones? If you do, take the overload off the bottom on the spring pack and bolt it to the bottom of the new lift springs, either right side up if you like to tow, or upside down for a better ride and more flex
