What to fill holes in with? (new side mirrors)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Dec 27, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    I got the rid of my nasty old tripod mirrors and got the newer style gm mirrors. But now i have these holes in the side of my doors, what should i use to fill them in with, I'm afraid bondo will fall in when four wheeling, will it? Is there a mesh type of thing to use? i don't have a welder but i could find someone to do it, what is the best way to go about doing this?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    When I painted my Blazer I welded the modeling holes, and grinded smooth. After that I used a little bit of Bondo to smooth it out. Hope that helps....same situation you are in....
    If it ain't a Chevy, don't raise it up!
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    what about filling it with solder? im not sure how well it would hold, but i would assume it would hold really well.
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    A trick we use to fill holes is to use a dis-similar metal on the back side of the hole and then weld it up. I usually use a piece of aluminum. After its welded up you can just remove the aluminum and presto, the hole is filled. On thin body metal I would use a thick piece so it'll absorb a lot of the heat and just do a series of tacks with some cool down between each tack weld. This should minimize the distortion. Then grind the outside flush and use some fill to smooth it.
    Rene
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Depending on how big they are you could use JB Weld.
    90K5
