What to look at when buying?
Discussion in 'The Garage' started by redefsen, Aug 6, 2004.
  1. redefsen
    redefsen Newbie
    Aug 6, 2004
    I am going to start looking for an 80's full size Blazer or Jimmy. What areas should I pay close attention to. I know of the frame by the steering box cracks. Anything else?
    Steve
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Stay away from rust if you can. Ihave a 84 Jimmy that the whole end where the tailgate is, it rotted out, it rattles like a bastard /forums/images/graemlins/yikes.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    the metal around body supports, especially up front under the radiator.
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    and the front floor pan areas
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If your area ( fill your profile out ) has emissions , make sure they are on there . A lot of people remove those to clean it up or to free up a couple ponies , they are likely to add up quick if you need to buy emissions stuff .
    Also , like everyone else says look for body rot . It is by far cheaper to buy a clean truck with bad motor , than a good motor with a bad body .
    Lots of people TRY installing stereos , CB's and gauges . Look at the wiring harness . It is much easier to add wheelin' accesories to a harness that won't catch fire or pop fuses /forums/images/graemlins/k5.gif
