What to look for on a 77?
Discussion in 'The Garage' started by Dafey, Apr 1, 2007.
  1. Dafey
    Dafey 1/2 ton status
    Feb 10, 2007
    2,675
    Roswell NM
    Im 99% sure Im buying a 77 tomorrow.:D
    What problems should I look for .Beside the frame at the steering... :confused:
  2. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    uh.. does the tranny work.. does the transfer case work... are the seals leaking on the engine.. tranny, transfercase, axles
  3. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    check the spark plugs, they can sure tell a mean story. check the fluids and for leaks. especially around the brakes and tranny. well anywhere. make sure all the expensive parts are good. and see if its got flattops.
    POST PICS!
  4. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    lets see 30 years old....hmmm everything?
    Seriously, the vehicle has probably had a few owners, each doing their own mods, maybe take someone with you who knows these trucks really good, body, and mechanically.
  5. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    Thanks for the replys!!
    Its only $1900.00 so I'm worried somethings wrong... :eek1:
    I`m going during the day to be able to see really good.I will check Really good underneath for leaks,check the oil and trans dipsticks,steering box/frame,a long test drive.Check for stains or leaks around the brakes and all around the diff`s.
    Are these [77] full time 4x4s?
    Whats a flattop?
    Are they HEI?
    I cant wait!! I have wanted a Blazer for 20 yrs...:bow: :p: :D
    I only wish it was 2 to 4 yrs older...
    And if I get it I will post pics tomorrow.Depending on what time I get home I`ll post as many as the daylight permits.
  6. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    dude 77 is the **** it was the only year GM offered the mustard colored stripe on the sides. if its all there thats a huuuge plus IMO.
  7. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    From the fuzzy black an white pic in the Thrifty Nickle ,it looks solid white.
    Which is one of the colors that I want!! :D :D
    He said the only things he know thats missing is the air cleaner [in the back seat ] and the a/c compressor .I`ll have to repair that !!! It gets to 100+ here. At least its a DRY HEAT LOL. :haha:
  8. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
  9. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Well. how did it go? Did you get it.
    Any pics?
  10. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    yeah x2
  11. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    Its 9:20..Im not going till 1:00 then its 100mi drive,so figure 4 hours round trip.Then I have to inspect it and stand around and bullsh*t for a bit...Wait till at least 7:00pm.
  12. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
  13. Seafarer76
    Seafarer76 1/2 ton status Premium Member
    Apr 10, 2006
    340
    Las Cruces, NM
    Some are full time, some part time, some are fulltime converted to parttime.
    Check the shifter lever and the hubs. If the shifter lever plate doesn't say 2wd on it, you probably have a NP203 (fulltime) transfer case. If it has lockout hubs, it probably has been converted to parttime. If the plate does say 2wd, you most likely have a NP205 (parttime).
    Some of these have a flattop steering knuckle on the passenger side, which allows for an easier/cheaper conversion to crossover steering. search and you will see.
    Yes, HEI.
    http://coloradok5.com/specs.shtml#1977
    What motor does it have?
  14. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    i dont ever run ac all year and i got a humid heat. coastal 100+ is awesome!!! :surepal: thats when i am kind of thankful i got a halftop blazer. only kinda.
  15. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    1 its full time,no lockout hubs yet.It goes 4lock -4h-n-4l-4lock.
    2 I forgot to check for HEI its to dark now...:o
    3 Its a fairly new motor,so Ill have to look and see what it is.
    4 Brand new trans an torque converter ,Don't know which one yet,but its gray..:haha: .I couldn't make out the sticker on it.And its missing the fly wheel cover.:rolleyes:
    5- 12 bolt rear .10 bolts on the front cover means its a 10 bolt right,same as the rear?:confused:
    My steering goes from the pitman to the left side on top,then from the left bottom across to the right....?:confused:
    It just needs a bunch of 20-50 dollar parts as far as Ive seen so far.:D
    Pics in a few,I have to upload them to photobucket then to here.
    Only 16 pic though,sorry.............:haha:
  16. Seafarer76
    Apr 10, 2006
    340
    Las Cruces, NM
    Its Hei...
    Could be anything then, most likely a 350 if they replaced it. In 77 you could get the 400 though. Since the flexplate cover is off anyway, you can look at the flexplate. If the flexplate has weights attached (spot welded) than you have a 400.
    Most likely a TH350, but you might be lucky and have the stouter TH400, check the pan shape.
    Probably a Dana 44 front. It will actually have D44 embossed into one of the webs on the center section. The cover is slightly D shaped as well. A 10 bolt has a round cover.
    Here's a little primer on what high steer/crossover steering is. The blazer does not have crossover from the factory.
    http://77cj.littlekeylime.com/flatop_knucles.html
    Good luck. I'm over $3000 into mine with no end i sight and I only paid $1000. Wait until you decide to lift it a little, replace axle parts, buy bigger tires, etc....
    These trucks are great at sucking the wallet dry.
  17. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    I dont know if its the parking lot or if the rear is sagging..?
    Both cables are busted..19.99 each.
    They cut holes ,dumbasses.
    more rust :(
    NO cracks :bow:
    :eek1:
    Bad ass seat covers...:haha: And my baby sitting in my new baby.:D
    Its in real good shape!
  18. Seafarer76
    Apr 10, 2006
    340
    Las Cruces, NM
    Looks like the interior is in great shape. You'll want to take care of that rust soon though before it spreads any further than it has. Other than that, the body looks pretty straight. Thats definately a Dana 44 front. About the same as a 10 bolt, just takes different gears. I see your engine has headers on it too, rather than manifolds.
    You really want to get a fan shroud first thing. The engine will definately overheat at slow speeds/traffic without one.
    Welcome to the club. Use this site....there's a wealth of knowledge here, all for the searching. Use the search tool alot....But if you can't find your answer, feel free to ask, the people here are great.
  19. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    They forgot to hook up the kick down,lol.
    The valve covers leak.But I think the slight film of oil on the bottoms coming from them.
    Its square with a drain plug in the front.
    It looks round to me.But I'm staying with the 33`s for a long time so its ok.And as of now I'm easy on the gas offroad.
    Well this is my favorite hobby,but I know how to wait and pay bills first [kids will teach you that :smirk: :rotfl: ]And to save up for what I need.
    NOT ME! I cant even sleep unless its 65 or so...:rolleyes:
    Over all I'm F**king happy as can be !!!!! :bow: :D :D
    So what do ya`ll think?Did I do good or what??
  20. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    niiiice dude! first thing i would do is wash the **** out of it!! then go through and replace all worn out steering components that obviously have been neglected. then you dont look to have any real leaks good plus. Does it have a tranny dipstick? looks funny. change all the fluids except the tranny unless it is still smlls and looks good, otherwise if its dark, i say leave a sleeping dog you know. get it to where its very reliable then, cut it up!
